Intake Manifold Flap Position Sensor P2015
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by 2009TDI, Jan 2, 2013.
  1. dieselgeek
    dieselgeek Site Sponsor
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    There have been plenty of people that have lost the spring but I have found that the spring is not under tension under any circumstances with a used manifold so it's not doing anything. The system works fine without it. I have a YouTube video about it here:
  2. Zapper
    Zapper New Member
    Dec 20, 2015
    VW Jetta TDI 2009
    Va
    I got this part the other day. I installed it today. I followed the video. It took me about 30 mins or so mostly back and forth for this thing or that thing. First set of hemostats was too small. Second set to big... back into the house again, that kind of thing.
    The hardest part for me was figuring out the damn electrical connector clip. You could laugh if you want but I am an Aircraft Electrician. I work on Blackhawks and Chinooks... the VW plug kicked my butt. I didn't want to break it. I am accustomed to cannon plugs. LOL
    Thanks to Jim's video, I had no trouble doing the job itself. I did not lose the spring. Code went off in a couple minutes with a few cycles of the key.
    Thanks Jim at Dieselgeek. Now, make the part cheaper LOL
  3. Edmond1821
    Edmond1821 New Member
    Feb 17, 2016
    2006 Volkswagen Jetta TDI 1.9l
    New York
    Greetings all,
    I am new to the forum and have the same P2015 code on my 06 VW Jetta TDI 1.9l and I would like to purchase the repair kit but I am not sure if it is the same for my engine as it is not stated that it is compatible with the 1.9l.
    I would appreciate the feedback.
    Edmond.
  4. ViBogdan
    ViBogdan New Member
    Oct 14, 2015
    VW Golf MK VI, 2.0 TDI(81kw)
    Bucharest - Romania
    I have a similar bracket installed but the voltage is 0.988 and I still get MIL on. Should I adjust my bracket so that I get the voltage down to 0.760?
  5. CPatterson
    CPatterson New Member
    Mar 15, 2016
    2010 Jett TDI
    Statesville, NC
    When trying to pop the linkage arm off the ball end that comes directly from the flap mechanism, the ball end snapped just after the bend toward the intake. This part looks to be maybe powdered metal and due to the space restriction I'm not sure welding is an option. This is looking hopeless at this point but really trying to avoid an over $900 repair!
    Anyone have any ideas?
  6. kasper
    kasper New Member
    Nov 16, 2009
    15
    2009 Jetta TDI highline manual 6 spd
    I placed a large strong magnet under the flapper motor to catch a wayward spring...it worked. The Dieselgeek bracket is the way to go.
    Cheers
    Ted
  7. hudeck
    hudeck New Member
    Aug 1, 2016
    5
    2009 VW passat cc 2.0 TDI
    netherlands
    to much
    @dieselgeek
    would this also work on my car.
    i have a 2009 VW passat CC 2.0 tdi.
    the reason i ask this is because i have the same errors as the rest here but VW garage told me that the whole manifold has te be replaced and that would set me back about €800.
    and this is in the netherlands
    and after looking around i noticed this simple but effective solution now im thinking if this would work then im a very happy man.
  8. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    Hudek,
    The P2015 fix will work perfectly in your CC. Just verify which manifold your car has and order accordingly off of our site. If you have the euro-only black plastic intake manifold we have a special offer you should read about.
    www.dieselgeek.com/P2015_Intake_Manifold_Flap_Position_Sensor_s/1900.htm
    Thanks,
    Jim
  9. hudeck
    hudeck New Member
    Aug 1, 2016
    5
    netherlands
    to much
    wow your fast ;)
    i think its best that i copy the error code including the type on this forum.
    because im more a electrical geek the mechanical i can do a lot myself regarding programming etc and diy.
    but for the rest mmmmm don't know
    this is the error code.
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 BL HW: 03L 907 309
    Component: R4 2,0L EDC G001SG 6221
    Revision: 13H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 83712 036 682247
    VCID: 70F6C71BFAA3E682EF00065-8024
    2 Faults Found:
    008214 - Intake Manifold Flap Position Sensor (Bank 1)
    P2016 - 000 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 255
    Mileage: 158691 km
    Time Indication: 0
    Date: 2010.10.18
    Time: 19:51:05
    Freeze Frame:
    RPM: 2070 /min
    Speed: 51.0 km/h
    Load: 91.0 %
    Lambda: 3.9 %
    Lambda: -4.7 %
    Voltage: 0.000 V
    Bin. Bits: 00000000
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Reset counter: 255
    Mileage: 158764 km
    Time Indication: 0
    Date: 2010.10.19
    Time: 12:27:01
    Freeze Frame:
    RPM: 1288 /min
    Speed: 33.0 km/h
    Load: 36.1 %
    Lambda: 3.9 %
    Lambda: -4.7 %
    Voltage: 0.304 V
    Bin. Bits: 00000000
  10. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    The .304V voltage reading at the bottom of your list confirms your manifold linkage is out of range. This is exactly what our bracket fixes.
    Thanks,
    Jim
  11. hudeck
    hudeck New Member
    Aug 1, 2016
    5
    netherlands
    to much
    Jim, thanks thats all i need to know.. Now I'll take a look at the manifold.
    Personally I think I got the aluminum verstion.
    If I order this part what does it cost and the shipping / handling to the Netherlands. How fast can I get it here
    do I need to use vcds to make some new settings or only to reset?
    And I took a better look at the arm and indeed the arm was on the ball instead of being on the right side of it
    Oke this is my aluminum manifold
    [​IMG]
  12. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    Hudeck,
    You can choose $4.99 USPS shipping for delivery within 4 weeks or you can choose FedEx for 3 day service for just under $26.00.
    Thanks,
    Jim
    Magnus likes this.
  13. hudeck
    hudeck New Member
    Aug 1, 2016
    5
    netherlands
    to much
    Ok I'm going to order the bracket with express.
    But do I have to take the motor of the manifold? Personally think that doesn't have to come off.
    And my second question do I need to recalibrate the motor?
    And to be sure I order the correct bracket
    Is this the right one
    http://www.dieselgeek.com/mobile/Product.aspx?ProductCode=EGR-P2015
  14. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    Hudeck,
    You do need to take the motor off to absolutely ensure that you get the P2015 bracket positioned properly. We see more problems from car owners that try to install the bracket without removing the V157 motor. You will not need to calibrate anything once the fix bracket is installed. Just make sure that the V157 motor is cycling upon engine shutdown and if not, pull the linkage arm forward while the engine is running to get it back into an acceptable range of motion and cycling again.
    The link you posted is correct for the aluminum manifold your CC has.
    Thanks,
    Jim
  15. hudeck
    hudeck New Member
    Aug 1, 2016
    5
    netherlands
    to much
    Jim... I posted a picture of my manifold a couple of posts back.. I got a complete new manifold 2years ago.. And it is a 2009 Passat TDI 2.0
    For the rest taking the motor of is no problem
  16. Olteanu Alexandru
    Olteanu Alexandru New Member
    Nov 3, 2016
    4
    Volkswagen Golf VI 6
    Constanta Romania
    Hello Jim. I have mounted the p2015 fix bracket and mounted on my golf VI 2.0 tdi from 2009 and I still et the mill on and the p2015 code on vcds
    Also the voltage from 121 raw 4 si 1.3 to 3.5... What do you think is the problem?
    I made a video here:
  17. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    Olteanu,
    There are some like you that have not had initial success with clearing the code. We have a secondary line of customer support for such situations which involves us sending an email with things to check. One thing you can do is run basic setting test in VCDS:
    Olteanu Alexandru likes this.
  18. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
  19. Olteanu Alexandru
    Nov 3, 2016
    4
    Constanta Romania
    Hi there Jim, thank you for fast reply
    Here are my voltages
    Basic settings 121 test in VCDS for P2015 CR TDI error code
    my lowest voltage is 1.216 v
    my highest voltage is 3.648 v
    And video of basic settings I took:
    I also see the same voltages on the
    Errors from log file of vcds:
    2 Faults Found:
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 159002 km
    Time Indication: 0
    Date: 2017.14.29
    Time: 15:24:07
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Lambda: -7.9 %
    Lambda: -11.8 %
    Voltage: 1.216 V
    Bin. Bits: 10001101
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 159002 km
    Time Indication: 0
    Date: 2017.14.29
    Time: 15:23:55
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Lambda: -7.9 %
    Lambda: -11.8 %
    Voltage: 3.648 V
    Bin. Bits: 10001110
    Readiness: 0 0 0 0 1
  20. dieselgeek
    Jun 9, 2011
    104
    2016 Golf TDI 6MT
    San Antonio
    1.216v at the low end is the highest I've seen by far and indicates something isn't right. Can you remove our P2015 bracket and do the test over and post the results? Posting a video to YouTube isn't really necessary. Just report the numbers here as you did above. I'm guessing that the bracket isn't seated quite correctly.
    Thanks,
    Jim
