Intake manifold and flap change
Discussion in 'Ross Tech VCDS forum' started by Stefab, Sep 10, 2016.
  1. Stefab
    Stefab New Member
    Sep 10, 2016
    Mk6, 2.0 Tdi
    Romania
    Hi All,
    Story is like this. Couple of weeks ago i got P2015 and P2016 as errors on my manifold. The intake flap motor was dead.
    I cleared all errors but i still had P2016.
    So, I purchased a refurbished manifold and a brand new flap motor, put them all together on the engine and i still have these errors. Actually the flap is till locked on open.
    From what a colleague told me, i should do a adaptation to the new flap motor i bought? would this fix my error?
    thanks for the advice.
    Address 01: Engine Labels: 03L-906-022-CBA.clb
    Control Module Part Number: 03L 906 022 LF HW: 03L 906 022 G
    Component and/or Version: R4 2,0L EDC G200SG 3691
    Software Coding: 0000071
    Work Shop Code: WSC 00191 264 15243
    VCID: 74E73A5B174EF4BE80B-8021
    3 Faults Found:
    008196 - Intake Manifold Flap; Bank 1
    P2004 - 000 - Stuck Open - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 210811 km
    Time Indication: 0
    Date: 2022.14.16
    Time: 18:26:08
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Load: 100.0 %
    Lambda: 97.8 %
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 78.3°C
    008198 - Intake Manifold Flap; Bank 1
    P2006 - 000 - Stuck Closed - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 210812 km
    Time Indication: 0
    Date: 2022.14.16
    Time: 19:24:34
    Freeze Frame:
    RPM: 1380 /min
    Speed: 54.0 km/h
    Load: 36.9 %
    Load: 15.3 %
    Lambda: 22.1 %
    Mass Air / Rev.: 375.0 mg/str
    Temperature: 77.4°C
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 210818 km
    Time Indication: 0
    Date: 2022.14.16
    Time: 19:35:42
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Lambda: -11.8 %
    Lambda: 0.0 %
    Voltage: 3.724 V
    Bin. Bits: 10001110
  2. Keithuk
    7,092
