Instrument cluster change
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Josh329, Apr 18, 2017.
  1. Josh329
    Josh329 New Member
    Jan 8, 2017
    6
    1998, Volkswagen, Jetta TDI
    Wilkes-Barre, PA
    Question for everyone, is it possible to change out an instrument cluster from a 97 2.0 GLS gasser to my 98 TDI? Mines bad in many ways and the gasser is still working. Both look the same but haven't messed with plugs or looked at lights.
    Sent from my XT1585 using Tapatalk
    23,902
    The gauge faces will be different since rpm range is different. Not sure otherwise.
  3. Josh329
    Josh329 New Member
    Jan 8, 2017
    6
    Wilkes-Barre, PA
    I'll have to double check but I'm pretty sure the rpm gauge is completely identical.
  4. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    i do not know if a gasser tach will even work on the diesel.. but #s are different
  5. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    RPM gauge is different on TDI (NO IGNITION).
  6. crsmp5
    Feb 14, 2012
    1,550
    85 kubvan
    but unlike pre tdi its run thru the computer vs off the alt... so i cannot say if a gasser one will not work.. both use the crank sensor as far as i know
