Installing replacement Airbag Control Module
Discussion in 'Ross Tech VCDS forum' started by mrrhtuner, Jan 28, 2016.
  1. mrrhtuner
    mrrhtuner New Member
    Mar 31, 2012
    6
    2010 Touareg TDI highline
    Hello everyone,
    I am going to do my best to explain my situation with my 2003 Jetta wagon TDI and it’s airbag control module.
    I purchased this car last winter locally. I was told that the airbag control module has a common fault/failure that causes the light to be lit up. When I got the car home, I ran a scan with VCDS and came across error: 65535
    I followed the information on Ross-tech’s page and haven’t been able to get this resolved.
    http://wiki.ross-tech.com/wiki/index.php/65535
    Here is my autoscan with the factory airbag control module:
    VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
    Data version: 20151216
    www.Ross-Tech.com
    Thursday,28,January,2016,11:44:43:47314
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    VIN: WVWSP61J53W434785 Mileage: 352600km-219095miles
    Address 01: Engine Labels: 038-906-012-AGR.lbl
    Part No: 038 906 012 GN
    Component: 1,9l R4 EDC G000SG 4308
    Coding: 00002
    Shop #: WSC 01266
    VCID: 62C19916EEF7632E07-4AEA
    WVWSP61J53W434785 VWZ6Z0B0367601
    2 Faults Found:
    18044 - Powertrain Data Bus
    P1636 - 35-10 - Missing Message from Airbag Controller - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 -
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
    Part No: 1C0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0004097
    Shop #: WSC 01266 785 00200
    VCID: 336F2C52518DBAA6BC-5122
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    012 - Electrical Fault in Circuit - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: 03 AIRBAG VW61 0202 0001
    Coding: 12339
    Shop #: WSC 01266
    VCID: 2757C802C555C60610-5122
    2 Faults Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    00588 - Airbag Igniter; Driver Side (N95)
    32-10 - Resistance Too High - Intermittent
    Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
    Part No: 1J0 907 487 A
    Component: Lenkradelektronik 0005
    Coding: 00118
    Shop #: WSC 01266
    VCID: 2F672022EDA59E46D8-5106
    No fault code found.
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J0 920 806 L
    Component: KOMBI+WEGFAHRS. RB8 V24
    Coding: 07332
    Shop #: WSC 93288
    VCID: 3065235EF09B81BEC1-5122
    1 Fault Found:
    01321 - Control Module for Airbags (J234)
    49-10 - No Communications - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01266
    VCID: 70E5E35E301BC1BE81-5122
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 8A Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 01266
    VCID: 3777184215F5568680-4AEA
    Subsystem 1 - Part No: 1C1959801A
    Component: 8A Tõrsteuer.FS KLO 0009
    Subsystem 2 - Part No: 1C1959802A
    Component: 8A Tõrsteuer.BF KLO 0009
    Subsystem 3 - Part No: 1C0959811A
    Component: 8A Tõrsteuer.HL KLO 0009
    Subsystem 4 - Part No: 1C0959812A
    Component: 8A Tõrsteuer.HR KLO 0009
    1 Fault Found:
    01358 - Internal Central Locking Switch; Driver Side (E150)
    27-10 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180 D
    Component: Radio NP2 0008
    Coding: 04401
    Shop #: WSC 01266
    VCID: 2143D61AAB7138365E-5106
    2 Faults Found:
    00878 - Connection to Speaker Front Left
    44-10 - Short Circuit - Intermittent
    01336 - Company Data Bus for Comfort System
    End-------------------------(Elapsed Time: 05:13)--------------------------
    Over the summer, I’ve sourced two airbag control modules from MK4 Jetta wagon’s and tried to install them but the light still is present. Knowing that there has to be more to this, I followed this guide this afternoon:
    http://wiki.ross-tech.com/wiki/index.php/Airbag_Coding
    I found that the description/images of the Index ID seems to be different on Ross-tech’s page than what comes on the control module.
    The image that Ross-tech shows:
    [​IMG]
    And what comes on my original airbag module:
    [​IMG]
    Regardless, below are the two other airbag control modules I was able to source:
    [​IMG]
    [​IMG]
    When I had the factory airbag control module installed, I went into 15-Airbags and Coding.
    The Software code/workshop was filled out.
    When I installed the airbag control module with the Index 01 number, the software code and workshop were the same.
    I am completely lost on how to get this replacement airbag to work and be rid of this code.
    I do realize that my scan earlier shows the airbag igniter – Driver’s side (N95) fault, it wasn’t there before so it may be something to do with the connection.
    When I was playing around with VCDS in the airbag coding section, there is no mention of a coding helper like the airbag coding page shows.
    I hope this is clear and I can clarify whatever is needed. With it being winter, I’m more concerned with getting the airbags to work for our safety.
    Thank you :)
