How to Remove ECU
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by ToeBall, Feb 16, 2012.
  1. ToeBall
    ToeBall Member
    May 25, 2011
    201
    2010 VW JSW
    APR Intake, PDE Downpipe, Banks Exhaust, Malone St
    Start by removing the plugs on the windshield wiper arms.
    [​IMG]
    _MG_0868 by Toe_Ball, on Flickr
    Remove the nuts and wiper arms. The arms will take some work to remove.
    [​IMG]
    _MG_0869 by Toe_Ball, on Flickr
    Next remove the rubber seal and the plastic cowel cover.
    [​IMG]
    _MG_0871 by Toe_Ball, on Flickr
    Finally, remove the two bolts and the cowl front.
    [​IMG]
    _MG_0872 by Toe_Ball, on Flickr
    The ECU is snapped into a plastic bracket. Remove it and pull it out as much as the harness allows.
    [​IMG]
    _MG_0874 by Toe_Ball, on Flickr
    Wrap the entire area with a blanket to keep from dropping metal particles and cut slots across the middle of the breakoff screws. The middle pins are a significantly harder material than the white outer pieces. Make sure to cut across them.
    [​IMG]
    _MG_0875 by Toe_Ball, on Flickr
    [​IMG]
    _MG_0877 by Toe_Ball, on Flickr
    Use a flat head screwdriver to carefully remove the break off screws and then pry open the security cage.
    [​IMG]
    _MG_0878 by Toe_Ball, on Flickr
    Pull the two tabs out to release the ECU from the harness.
    [​IMG]
    _MG_0879 by Toe_Ball, on Flickr
  2. golfTDI1
    golfTDI1 Member
    Oct 25, 2010
    308
    2010 VW Golf TDI 6M 4dr
    New York, USA
    see signature
    Very nice write-up ToeBall...on behalf of all, thanks.
  3. ToeBall
    ToeBall Member
    May 25, 2011
    201
    2010 VW JSW
    I've done about 3 of these and a 4th one's on the todo list. I've got some of the photos to continue this to a full DPF pull, but I keep getting more and more into the job, and don't want to grab my camera with dirty hands.
    [​IMG]
    _MG_0897 by Toe_Ball, on Flickr
  4. agoodhi
    agoodhi Member
    Jul 13, 2011
    77
    2011 Golf TDI
    Do you reuse the slotted bolts, or get new ones?
  5. ToeBall
    ToeBall Member
    May 25, 2011
    201
    2010 VW JSW
    You can buy new security bolts from the parts counter for about $2 each, but I just leave the whole security collar off.
  6. agoodhi
    agoodhi Member
    Jul 13, 2011
    77
    2011 Golf TDI
    When the dealer updates the firmware, do they go through the same process, or is there a port they simply plug into?
  7. chittychittybangbang
    23,804
    They just plug into the obd2 port
  8. turbobrick240
    turbobrick240 Member
    Jan 9, 2012
    37
    VW golf tdi 2011
    superchips flash, B2 every tank since new, elbrus
    nice writeup toeball. I would just add that the ecu location is different on the pre 2010? vw common rails. The Malone Tuning page has a great photo tutorial on ecu removal for both ecu locations. Happy tuning!
  9. oldval225
    oldval225 New Member
    May 3, 2012
    49
    Golf 2008 1.9 tdi
    Is the Malone Tuning 1.5 or stage 2 upgrade a direct replacement ECU, or do you send yours to them for modification?
  10. domenai
    domenai New Member
    Jun 8, 2012
    VW jetta sportwagen 2012
    None yet
    Did you build that exhaust or is it ordered? If so where from. And if you made it, how much for the build?
  11. ToeBall
    ToeBall Member
    May 25, 2011
    201
    2010 VW JSW
    You take yours out and ship it to Malone
    Not sure what you mean. It's a PDE downpipe, a Magnaflow muffler, and a Borla cat-back. There's also a piece of 2.5" stainless pipe inline with the muffler on the car.
  12. wbg
    wbg New Member
    Aug 16, 2013
    13
    1999
  13. JacktheBear3
    JacktheBear3 New Member
    Oct 7, 2011
    None
    anyone know if Banks (or anyone else) has a 3" turbo back exhaust for the JSW / 2012+ ???
  14. aamizan
    aamizan New Member
    Feb 17, 2017
    TDI Jetta 2013
    Los Angeles
    my mechanic told me that the ECU on my 2013 Jetta needs replacement because it kills the engine depsite all the sensors working etc. Do you guys know if i can just swap it for a used ECU in good condition or do i need to reprogram it. He told me i might need to go to the stealership to reprogram it because he cannot do it without the VW computer
  15. Keithuk
    6,850
    Nice write-up from an old thread.
    My ecu is under the carpet on the passenger side on my 2010 Golf the same as your 2010 VW Golf TDI.
