how do u get a tdi in time so u can fine tune it
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Lynn $21, Oct 28, 2016.
  1. Lynn $21
    Lynn $21 New Member
    Oct 26, 2016
    4
    vw Jetta tdi alh 2001
    Clearfield
    egr delete, and after market air filter
    I replaced the head gasket on my 2001 alh tdi Jetta and when I went to start it the tensioner was not tight enough and it jumped time. Luckily it did not bend any values. I would like to know how to get it back in time so I can get it fine tuned.
  2. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    You have to "reset" the belt. AKA repeat procedure and not outcome.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,794
    Scotland
    PP764's, turbo and mapping
    Yeh you need to line it all up as per the faq or diy index pages. It's pretty straight forward though.
    Once you've got it all lined up then you can reset the tensioner or replace if need be.
  4. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    786
    06 TDI Jetta
    Marysvile, WA.
    So how do you know you don't have valve damage? If you turned over with it out of time, you probably do. TDI valves do not bend, they compress when you have a valve to piston collision so you could put it back in time and it would seem to run fine until a valve head drops off into the cylinder within the next few thousand miles.
    TDI's are interference engine and being even a tooth or 2 off will cause valve to piston damage.
    Magnus likes this.
  5. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,433
    85 kubvan
    valves cost less then head/piston/rod when head pops off..
