How do I get my PD Injectors out?
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by robinofbristol, Jun 3, 2011.
  1. robinofbristol
    robinofbristol New Member
    Apr 26, 2011
    21
    A3 1.9 TDi PD ASZ Sport
    Old school hotrod guy at heart, this one is the fa
    Finally gave up on the engine and have bought a 40,000 mile replacement which arrived today. Changing over all the missing bits I decided to swop the rocker covers and couldn't believe my eyes...the swines have taken the injectors out and stuck the cover back on. So I need to swop out my original injectors to the new engine...I got the bolts and spacers out and I can turn them a little left and right...but how on earth am i supposed to pull them out? I can't see anything else holding them in place so I guess it is just the O rings being tight. Should I wrap some wire round the springs and tie them to the engine hoist and try pulling them out of the engine? I can't get a lever in there and I can't think of any suitable tool...even if I has a slide hammer I have no way to attach it.
    Any suggestions.... anything considered.
    23,900
  3. robinofbristol
    Apr 26, 2011
    21
    Very helpful.... but I need them out tomorrow, I can't wait 3-5 days for a T10055 special pulling tool. It looks fairly basic, I might try making one while my Son tries all the VW specialists in town to see if anyone has one off the shelf. Oh well at least I know there is a place I can use to lever them out... I am on the right track.
  4. robinofbristol
    Apr 26, 2011
    21
    DIY Injector extraction tool
    As I couldn't wait....I decided to shave one side off a long (motorbike engine) bolt, I guess the shaft was about 8mm and 220mm long and the head about a 15 or 16mm with a built-in washer...the nut for the other end was the same design. I filed down one flat right to the shaft of the bolt and filed of about half of the top surface too. the remaining lip hooked nicely into the side of the Injectors (where the retaining spacers came out) and all I needed was something with some weight to use as a slide hammer. One of my medium sized axle stands temporarily gave up it's middle and the pin holes just happened to be a nice loose fit over the bolt...nut in place and a couple of upward taps and... bob's your uncle.
    Now how much did they want for that T10055 special tool that would take 4-5 days to deliver?
  5. chittychittybangbang
    23,900
  6. jetta27
    jetta27 New Member
    Aug 29, 2011
    7
    2004 Jetta
    Injectors will not move
    sorry to jump in but I am having a similar problem.
    I am trying to get my injectors out but unlike your injectors mine will not move. I can not get them to even adjust left to right. I made a tool as you did and nothing will budge! I have to get them out because they are leaking diesel into my oil. Is there anything I can do to try to get these things out?
  7. gotdisl?
    gotdisl? New Member
    Jun 25, 2012
    2004 Jetta TDI PD
    removing injectors
    Anybody in NC, near charlotte has the T10055 tool for sale or for me to rent/borrow? Injector removal tool!!thanks
  8. CraigT
    CraigT New Member
    Feb 23, 2013
    4
    2004 mk iv
    Good day I stripped the head down and put in the oven at 150 degrees F. I found that the injectors came out alot easier and they woouldn't budge before I warmed the head up.
    Cheers and good luck
    dweisel likes this.
  9. chudzikb
    chudzikb Member
    Feb 3, 2011
    434
    05.5 Jetta, 03 2 door Golf
    Lancaster PA
    Nice tip, I can see my wife killing me for doing that one, would not be good for me!
  10. sgtgoober
    sgtgoober New Member
    Dec 18, 2012
    16
    00 Jetta
    Little Rock, AR
    .205 injector nozzles
    The injectors in my ole TDI were pretty stubborn about coming out until I sprayed a little PB blaster then used the metalnerd slide hammer. I've heard of some ppl using an old fuel line as well.
  11. lukeykookey
    lukeykookey New Member
    Jan 8, 2014
    5
    vw touran 2.0tdi
    Manchester, UK
    none
    HI everyone. Absolutely great site! (Although cant see a link to donate??)
    Anyway. I have the same issue and need to remove an injector on my VW AZV 2.0tdi engine, after C2 misfire issues (changed loom already at £100 - no difference)
    This engine is a DOHC. Are there any tutorials for this - I imagine the procedure is very similar but don't want to do something wrong.
    Many thanks in advance and keep up the good work - also how do I donate!
    mk5tdi likes this.
  12. lukeykookey
    Jan 8, 2014
    5
    vw touran 2.0tdi
    Manchester, UK
    none
  13. Ted Tolentino
    Ted Tolentino New Member
    Sep 4, 2016
    7
    Jetta, TDI, 2002; Passat, v-6, 2002
    Oklahoma City
    robinofbristol, if you still have your home made tool for pulling the PD injectors, could you share a picture or two of what the tool looks like. I, too, have injectors I need to remove from my 2004 PD engine. A million thanks.
  14. morganc
    morganc New Member
    Oct 17, 2017
    2005 allroad tdi
    reno, nv
    tdi
    I used robinofbristol's technique and it works well. I had a slide hammer and got a bolt that fit it. I shaved down one side and the top to make it thinner. Slipped it in...tap tap tap and it out. I'll upload pics. Cost was $2 for a metric single bolt at home depot in M 14X80.
