Hole in ALH tranny..fixable?
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by westly7, Oct 16, 2017.
  1. westly7
    westly7 New Member
    Oct 9, 2017
    01 vw jetta tdi 5speed
    Little rock ar 72205
    my mk4 has dripping oil from between motor and tranny case.took out the tranny and found hole in tranny housing,i dont know it was there bc of the clutch mechanism or bc when i took it out i wiggle too much and hitting thw clutch...anyways do you think this fixable?
    Here pic,also there is rubbing mark on its right side
  2. Mr.loops
    Mr.loops New Member
    Jun 28, 2017
    2002 Jetta TDI
    Kelowna
    You have bigger problems with the inside of your transmission. It looks like either your roll pin or diff bolt has let go and has cut a hole in your bellhousing
    You need to do a teardown and rebuild . It might be cheaper to source out a used 02J
  3. Dave N
    Dave N Member
    May 31, 2015
    53
    06 Golf TDI BEW 09A
    Spokane Wa
    Looks like you have quite a few cracks as well.
