Hiss near firewall and turbo vibration
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by HootieBird, Jan 11, 2017.
  1. HootieBird
    HootieBird New Member
    Aug 18, 2014
    7
    VW Golf TDI 2005
    Whitesburg, Ky
    There is a hiss while idling with exhaust escaping towards firewall side of engine as well as what sounds like the turbo rattling near 2300 rpm. I assume these issues are related but not sure. Thanks for any helpful feedback.
  2. John Mack
    John Mack New Member
    Nov 3, 2015
    23
    2005.5 JETTA TDI /2015 JETTA TDI
    OREGON
    If you have a 2005.5 or 2006 Mk5, the hiss at idle could be the exhaust gas cooler. A shaft seal goes out on an internal flapper and the leak gives a hissing noise at idle. You may also note a slight odor of diesel. There are ways to repair the shaft seal without removing the cooler or spending $300.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  3. Erich
    Erich New Member
    Jun 28, 2015
    19
    Vw Jetta tdi 2000
    burlington
    Hiss at idle makes me think vacuum leak. Check all hoses and turbo actuator which is controlled by vacuum. It actuator may have rusted out and the pieces might rattle around at certain rpms.
  4. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,505
    85 kubvan
    AND they crack egr pipes also
  5. HootieBird
    Aug 18, 2014
    7
    VW Golf TDI 2005
    Whitesburg, Ky
    Sorry I forgot to post that it's an 05 pd golf.
  6. crsmp5
    Feb 14, 2012
    1,505
    85 kubvan
    . so egr cooler or cracked egr pipe.. both hiss and blow soot/exhaust at firewall
    HootieBird likes this.
  7. John Mack
    Nov 3, 2015
    23
    OREGON
    A vacuum leak will not blow soot on the firewall, an exhaust cooler leak will. Check where the shaft for the butterfly comes out of the cooler. There is a lever arm attached to the shaft that attaches to a vacuum actuator via a small link shaft. The seal is the most common cause of a leak from the cooler. The leak is fixed from under the car. Remove the big splash panel and look around the bottom rear part of the engine. The exhaust gas cooler is cylindrical and mounted horizontally to the engine block. Removal of the passenger side drive axle will give good access to the shaft and cooler.
  8. HootieBird
    Aug 18, 2014
    7
    VW Golf TDI 2005
    Whitesburg, Ky
    To be clear I'm not sure soot is being released. I just know exhaust is.
