Help with abs coding
Discussion in 'Ross Tech VCDS forum' started by Whagunere, Sep 25, 2012.
  1. Whagunere
    Whagunere New Member
    Sep 16, 2012
    4
    2012 JSW TDI
    Hey guys I have a '12 jsw tdi and I went to swap the wheel for one with paddles, so I swapped the wheel and then set the vcds for tiptronic. Turned the ignition off then turned it back on. When I restarted the car I had a number of flashing lights, besides the steering sensor. turns out that for some reason the abs control module lost it's coding and is now all zeros! Unfortunately, my saved file for my stock settings was on my old laptop that crashed :( Could anyone please tell me what the coding is for that module? Thanks in advance! It would be nice to have abs and traction control again :nana2:
  2. Keithuk
    7,235
  3. Dana @ Ross-Tech
    Dana @ Ross-Tech New Member
    Aug 18, 2010
    18
    02 Gti, 10 Gti
    That vehicle should use the 19 byte long coded MK60EC1 which is online SVM / dealer at this time. If you have a scan saved prior to any modifications the original coding can be used but you may need to enter a specific security access code prior to it being accepted. Post any of the Auto-Scan information you happen to have saved.
  4. Whagunere
    Sep 16, 2012
    4
    2012 JSW TDI
    Okay, sorry it's taken so long for me to reply I had an emergency and have been out of town. Anyway, I scanned my car again yesterday just to show you where i'm at. I also scanned my brother's 2012 Jetta sedan tdi to see if our part#'s and everything matched. Turns out that everything in the abs section is the same which i'm sure you already knew :) So I tried inputing the long code into the helper (B14B400C492300FE8D1102E8921D0042A71000), then hit done. I get the
    I get the "error 31 not in range" code on my screen. I even went back and tried it with unlocking the security to get the same result. Now I was thinking earlier, the digits for workshop # have always been blank on my vcds. Should I match the numbers for the workshop #'s that are in the scanned section for my car?
    Thanks for your help!
    Sunday,30,September,2012,18:17:13:42378
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    jml
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
    77
    VIN: 3VWPL7AJ8CM680055
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    1C-Position Sensing -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 HG HW: 03L 907 309 AA
    Component: R4 2,0L EDC G000AG 3522
    Revision: 12H14--- Serial number:
    Coding: 0050078
    Shop #: WSC 00066 000 00000
    VCID: 77FD50E20668CEA010F
    1 Fault Found:
    008408 - Exhaust Re-Treatment Post-Injection
    P20D8 - 001 - Control Limit Reached - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 9694 km
    Time Indication: 0
    Date: 2006.14.00
    Time: 06:11:01
    Freeze Frame:
    RPM: 2346 /min
    Speed: 118.0 km/h
    Torque: 204.0 Nm
    (no units): 0.88
    (no units): 0.94
    Temperature: 336.0°C
    Load: 23.9 %
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 057 P HW: 02E 927 770 AL
    Component: GSG DSG AG6 512 3102
    Revision: 05551213 Serial number: 00001201181464
    Coding: 0000020
    Shop #: WSC 02069 000 90108
    VCID: 26434DA6914287287B9
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 00066 123 12345
    VCID: 7DF142CAE454E4F04A3
    3 Faults Found:
    03306 - Coding Not Valid
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 10089 km
    Time Indication: 0
    Date: 2006.14.04
    Time: 04:17:55
    Freeze Frame:
    Count: 3
    Count: 32780
    Count: 12800
    Count: 4161
    Count: 49920
    Count: 0
    Count: 0
    Count: 0
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 9955 km
    Time Indication: 0
    Date: 2006.14.03
    Time: 02:59:21
    Freeze Frame:
    Count: 7
    Count: 12
    Count: 12800
    Count: 320
    Count: 49408
    Count: 0
    Count: 65024
    Count: 0
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 9955 km
    Time Indication: 0
    Date: 2006.14.03
    Time: 02:59:21
    Freeze Frame:
    Count: 7
    Count: 12
    Count: 12800
    Count: 195
    Count: 49408
    Count: 0
    Count: 65024
    Count: 0
    Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
    Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
    Component: AC Manuell H19 0404
    Revision: 00001016
    Coding: 0000001002
    Shop #: WSC 00066 000 00118
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW36.rod
    VCID: 800FBB3E1BA60918A15
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
    Component: BCM PQ35 B 021 0064
    Revision: BG021001
    Coding: 2F380EBF80297EE4E04808C1250000A84970008153000540648021200000
    VCID: 397996DAB0FC18D026B
    Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 12031 26 0512
    Coding: 009795
    2 Faults Found:
    00323 - Vehicle Inclination Sensor (G384)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 9955 km
    Time Indication: 0
    Date: 2006.14.03
    Time: 02:59:21
    Freeze Frame:
    Term 15 On
    Voltage: 13.90 V
    ON
    ON
    OFF
    OFF
    OFF
    03252 - Engine Control Module for Hybrid Drive
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 9955 km
    Time Indication: 0
    Date: 2006.14.03
    Time: 02:59:25
    Freeze Frame:
    Term 15 On
    Voltage: 13.85 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
    Component: AirbagVW10G 013 0724
    Serial number: 003GVRA1B32I
    Coding: 00003133
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3F8DF8C2A6D836E018F
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
    Component: BF-Gewichtss. 006 0001
    Serial number: ---0000R--000038RW00
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME06525568ZZZU
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME2F247467ZZZ+
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3511HSME5E21212BZZZJ
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3521HSME4108222BZZZC
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME79346929ZZZP
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME05256929ZZZF
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422LAU000MW
    Coding: 081A144000
    Shop #: WSC 00066 123 00187
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 76E35DE6C962B7A80B9
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H09 0013
    Serial number: 0098633
    Coding: 020000
    1 Fault Found:
    267264 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 81
    Mileage: 9955 km
    Date: 2006.14.03
    Time: 02:59:20
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
    Component: KOMBI H03 0607
    Serial number: 00000000000000
    Coding: 270D00
    Shop #: WSC 00066 123 00118
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 306FABFE6B86D998915
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 P HW: 1K0 907 951
    Component: J533 Gateway H40 1623
    Revision: H40 Serial number: 24021201291035
    Coding: 352002
    VCID: 3D7182CAA4D424F00A3
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223RG5VS06
    Coding: 0000002
    VCID: FEF3C5C6A9527FE8D39
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0607
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EADBF9960DDAE3481F1
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7661539546
    Coding: 010000
    VCID: 2959469A405CA85056B
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 701 HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0501
    Revision: 13110009 Serial number: 0004200825
    Coding: 0204B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: DBB5AC52D2808AC0947
    Slave Driver:
    Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D
    Component: J388__TSG-HL 007 1509
    Serial number: 00000006422912
    Coding: 000490
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 N
    Component: EPS_ZFLS Kl. 70 3301
    Revision: 00H22000
    VCID: 35619AEA5CE4FCB0C23
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 1K0 907 951
    Component: EZE_2 H40 1623
    Coding: 050A0500
    VCID: EFEDE8823E38066048F
    Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J245EE20SKB13 H03 0220
    Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
    Component: J394EE20SKB13 H03 0220
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 561 959 702 HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0501
    Revision: 15110009 Serial number: 0004171754
    Coding: 0204B4
    ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
    ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
    VCID: DCB7AF4ED78E8DF89DD
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D
    Component: J389__TSG-HR 007 1509
    Serial number: 00000006338767
    Coding: 000490
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
    Component: Radio Prem-8 H02 0016
    Revision: -----16S Serial number: VWZ4Z7M3263560
    Coding: 01000401040007
    VCID: 63C514B262F032005C7
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 9955 km
    Time Indication: 0
    Date: 2006.14.03
    Time: 02:59:19
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
    Component: TELEFON H12 2902
    Revision: 1B001001 Serial number: 00007661721826
    Coding: 0A11020000010100
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW36.rod
    VCID: 275D40A25E489E2040F
    End ---------------------------------------------------------------------
  5. Whagunere
    Sep 16, 2012
    4
    2012 JSW TDI
    Any input would be helpful, i really dont wanna try anything else until then. Dont wanna make it worse :)
  6. Keithuk
    7,235
    Sorry I can't make anymore suggestions only take it back to the dealer.
  7. Henrick
    Henrick New Member
    Feb 25, 2012
    5
    Golf V 2005
    I know this is a very old thread, but I thought I'd rather say, in case someone might find it useful.
    I can calculate lost ABS MK60EC1 codings in fact for any car which had that module fitted from factory.
    In addition to that, I can assist with retrofitting/rewiring these modules.
    Let me know if you need help.
