Heated seats will not work
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Itlog18, Dec 29, 2017.
  1. Itlog18
    Itlog18 New Member
    Jun 24, 2017
    4
    VW Jetta TDI 2006
    Gloucester, VA
    I have a 2006 TDI and both of my seat heaters stopped working. I got a fault from vcds of 02092 and is says open or short to ground. I checked the fuse and it is good. Does anyone know where the ground to this system is located or if it has a relay. I am new to the Jetta and it is becoming a very frustrating car. I fix one thing and then something else goes bad. (Now my sunroof is possessed)
    Thanks for any help
    Charles
  2. Keithuk
    7,235
    Do you have the correct fuse & relay layout?
    Fuse 37 - 30A - J131 - Heated driver seat control unit, J132 - Heated front passenger seat control unit
    Fuse & Relay PDF Files
    VAG Error Code: 02092
    Fault Location:
    Enabling Heated Seat - Open Circuit/Short Circuit to Earth
    Possible Cause:
    Seat Heating not working.
    Fuse(s).
    Wiring/Connector(s) from/to Central Electronics Control Module (CECM) (J519) from/to Seat Heating Control Module faulty.
    Control Module incorrectly coded.
    Possible Solutions:
    Check/Replace Fuse(s).
    Check/Replace Wiring/Connector(s) from/to Central Electronics Control Module (CECM) (J519) from/to Seat Heating Control Module.
    Check Control Module Coding.
  3. Itlog18
    Itlog18 New Member
    Jun 24, 2017
    4
    VW Jetta TDI 2006
    Gloucester, VA
    I apologize for the lack of introduction. My name is Charles and I have a 2006 Jetta TDI that has 185,000 miles. I recently moved from Gloucester, VA to Azle, TX. I was active duty Air Force for 15 years but am now in the Guard.
    I have no blown fuses. My biggest thing is trying to locate all components of the circuit(grounding point), wire diagram, and how to ops check the control module. This is very frustrating because of not knowing what plugs are what and plastic covering everything!
    Thanks for any help and sorry for me venting a little.
  4. Keithuk
    7,235
    The only way you will get wiring diagrams and earth points is if you have ElsaWin or https://erwin.volkswagen.de/erwin/showHome.do and pay for usage for as long as you want info. You can save anything to a PDF file for future reference.
  5. Itlog18
    Itlog18 New Member
    Jun 24, 2017
    4
    VW Jetta TDI 2006
    Gloucester, VA
    Thank you! It’s a start.
  6. gt4494
    gt4494 Active Member
    Jan 15, 2011
    440
    2005 NB
    Southeast Coast on I-95. Radar detector on and yes Herbie still gets 40mpg at 80 mph
    Welcome aboard!
    I think Bentley still makes a manual. Might be CD only now.
  7. gt4494
    Jan 15, 2011
    440
    2005 NB
  8. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
  9. Itlog18
    Itlog18 New Member
    Jun 24, 2017
    4
    VW Jetta TDI 2006
    Gloucester, VA
    Thank you for the help! I will keep you posted on what I find.
