Had any trouble in a PD tdi?
Discussion in 'Biodiesel general' started by Kartmanz, Apr 10, 2013.
  1. Kartmanz
    Kartmanz New Member
    Apr 10, 2013
    Ibiza tdi
    Just a quick question to see if anyone runs biodiesel in a PD engine and what if any, problems have occurred?
    I've heard bio gunks up the nozzles and causes bad running? And vw only recommends a small amount be used.
    Thanks in advance for the help
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,744
    Scotland
    PP764's, turbo and mapping
    Not just nozzles, it can also clog the rings up badly, there was a thread recently on the tdi club, you want to see the state of the guys engine after running bio for a while.
  3. SkyLayner
    SkyLayner New Member
    Apr 17, 2013
    2005 VW Passat
    WVO - cautions
    I have a 2005 VW Passat TDI I converted with a Greasecar kit several years ago when the car had only 25K miles on it. Currently we have 125,00 and have had some issues mainly due to operator error. Full purging the engine in Rocky Mountain weather is critical. My setup had the valves ~2.3 ft from the injection pump so it takes a while to purge. As such Dumb a$$ me forgot to purge before we got to the hotel (on a ski trip) and let it idle for 5 or so minutes. The engine doesn't use much fuel at idle so I think the system wasn't purged. Next morning VERY hard to start, but finally did. That happened twice.
    Shorter lines and perhaps a timer to automatically shut down the system is a really good idea.
    I had some significant blowby for several months and treated the engine with a GM product to unstick rings (apparently a problem with some Caddys) when I changed out the turbo. Took out glow plugs squirted 100 mL of stuff, rotated the engine, let it soak, and repeated . I put a cloth over the exhaust manifold and started w/o the turbo. Good thinking as chunks of crap came out. I also treated the fuel for 6 months and the blowby seemed to abate. Other than that the car runs strong.
    The oil/balance shaft chain issue is still a big worry though. Just bought a kit from Bora to eliminate the balance shaft.
    WVO has also gotten harder to obtain.
  4. goldstar
    goldstar New Member
    Feb 18, 2011
    20
    Polo 1.4 Tdi 2003
    Polo PD 1.4 TDI AFM 100% bio, never a problem.
  5. gt4494
    gt4494 Active Member
    Jan 15, 2011
    415
    2005 NB
    Southeast Coast on I-95. Radar detector on and yes Herbie still gets 40mpg at 80 mph
    2005 NB 210K miles, nothing but oil changes and normal preventive maintenance. I do need the alternator clutch changed. Alternator is original..
  6. gsmiley
    gsmiley New Member
    Jul 25, 2010
    7
    I use water-washed and dried biodiesel in my 05 PD Caddy, 100% in warm weather, about 50% in (S. Australian ) winter where freezes overnight occasionally. Seeing what I refine out of used oil I wouldn't be caught dead using uncatalysed veg oil. Runs very clean. Only one problem at first internal fuel pump filter gunked in cold weather. This vehicle does NOT have a diesel particulate filter which can initiate a clean-out cycle in which fuel is injected on exhaust stroke leading to sump oil contamination from unburnt bio off cylinder walls.
  7. jjschicken
    jjschicken New Member
    Apr 19, 2012
    Jetta TDI 2005
    Running b5-b50 for 5 years in 2005 jetta (bew) with no related problems.
    I now make biodiesel for a living and can answer must questions abit the fuel. Www.fullcirclebiofuels.com
