Got a CEL code P0544?
Discussion in '2012-2016 VW Passat TDI forum' started by jimbbski, Sep 26, 2016.
  1. jimbbski
    jimbbski New Member
    Sep 26, 2016
    2012 Jetta TDI
    Chicago
    Stock
    Not sure if the TDI has one or two sensors? Also if it has two which is bad? Upstream or down stream?
    Dealer wants $400+ to replace. I can and want to do this myself.
    23,734
    That's the code for #1 so I'd refer to the parts diagram to double check.
    You could follow the plug, unplug, see if additional code pops up.
  3. Keithuk
    6,771
    VAG use 5 Exhaust Gas Temperature (EGT) Sensors. These have been talked about before if you search?
    Exhaust Gas Temperature (EGT) Sensor 1 (G235)
    Exhaust Gas Temperature (EGT) Sensor 2 (G236)
    Exhaust Gas Temperature (EGT) Sensor 3 (G495)
    Exhaust Gas Temperature (EGT) Sensor 4 (G648)
    Exhaust Gas Temperature (EGT) Sensor 5
    If you fit a new sensor I think you will need access to VAG-COM\VCDS to calibrate.
    VAG Error Code: 16928/001348
    EOBD II Error Code: P0544
    Fault Location:
    Exhaust Gas Temperature (EGT) Sensor 1 (G235), Bank 1 - Circuit Malfunction
    Possible Cause:
    Wiring/Connector(s).
    Exhaust Gas Temperature (EGT) Sensor 1 (G235).
    Engine Control Module (ECM).
    Possible Solutions:
