Golf IV 1.9 Running Rich at Low rpm, Lean at high rpm
Discussion in 'General Diesel Discussion' started by Shyqyri Rama, Aug 16, 2017.
  1. Shyqyri Rama
    Shyqyri Rama New Member
    Aug 16, 2017
    VW Golf IV 1.9 PD Engine Code ATD 4 Motion Manual Shift
    Kosovo
    Hello guys,
    A few months ago I bought a golf 4 tdi 1.9 PD with a engine code ATD.
    In the beginning it went like a dream, but now has developed some strange driving issues, when the engine starts cold, it has a clicking noise and if you push the gas pedal, the rpms will drive you mad, rpm barely move and i suspect its running rich( no smoke), when engine is hot the knocking sound from engine backs of a little bit doesn't go away and if you try acceleration on WOT when it goes over 3000 rpm seems like no power at all, checked with VCDS no codes no nothing, the power is not as it was before it doesn't take of as it was doing it before. I feel some judder while in 1st and 2nd gear low rpm. On WOT 2nd gear acceleration is slow until 2000 rmp then boom, power comes back until 3000 rpm , after that still going slow.
    Timing belt was done 2K km before including camshaft and lifters, camshaft was a little worn out and my mechanic changed it.
    My checks till now:
    Vaccum leaks -none Tandem pump pipe moving a little bit
    Vaccum pressure - 25 to 28 psi
    Turbo vanes stuck- no they move freely
    When you hit the pedal you can hear the turbo spooling
    MAF reading - 235 at idle, requested vs actual difference 10 to 20 mg/str at WOT
    Injection quantity 3.6 mg/str
    injection deviation cly 1 : 0.78 mg/str
    injection deviation cly 2 : -0.14 mg/str
    injection deviation cly 3 : 0.00 mg/str
    injection deviation cly 4 : -0.66 mg/str
    Thanks
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    Test the maf under load, 3rd gear foot to floor. A bad maf tends to stay 550 or below.
    More info on that in the faq pages, just use the bew faq, mostly the same.
  3. Shyqyri Rama
    Aug 16, 2017
    Kosovo
    Hello Seatman thanks for the replay Already teste the maf at wot 3rd gear difference between actual and requested is max 10 mg ie requesting 880 actual is 870 or 890
