FS; 2002 Jetta TDI 1.9 5 speed ALH PA 18013
Discussion in 'Diesel Cars and SUV' started by Dcross_, Oct 6, 2015.
  1. Dcross_
    Dcross_ New Member
    Mar 25, 2015
    12
    02 Jetta TDI
    Bangor
    First things first... No check engine light or any other dashboard light.
    Car is inspected 4/2016
    Up for sale is my 2002 Jetta tdi 173k miles. Black cloth interior, seats are heated!! Power windows locks and sunroof. Engine code is ALH. Car has no rust on it. After the down pipe the car has a 3" straight pipe with a 3.5 inch MBRP exhaust tip. Yes it makes the whoosh sound when you shift. Tinted windows. Also have roof rack with snowboard attachments and keys. Inspected. New outer tie rods on both front wheels. Did a 5 year wheel alignment a couple months ago so it still has 4.5 years left of unlimited wheel alignments at Jack Williams Tire. Also has a block heater installed for the winter time so no hard starts and instant heat. Car is tuned from Malone tuning with a stage 1.5. Comes with a controller through Malone that holds 3 tunes so stock is still a option. Pp520 nozzles were installed on the injectors. They were pop tested before installing. 50+ mpg. I do not daily this car. Timing belt was last done at 90k miles. It does not burn or leak oil!!! Always changed with full synthetic oil. 5% tint on all windows. 35% on windshield. Car runs great. Would trade ONLY for a Honda S2000 with cash on my end. That's the only car I'm really interested in. Clean title in hand.
    The bad:
    E brake doesn't work, gas door doesn't open with button. Car needs a wheel bearing, groans when you turn right.
    Call or text anytime, 4848920606 thanks dan
    $5200
  2. Dcross_
    Dcross_ New Member
    Mar 25, 2015
    12
    02 Jetta TDI
    Bangor
  3. TDIvr6
    TDIvr6 New Member
    Jan 27, 2014
    5
    volkswagen, jetta tdi, 1998
    wilkes barre, pennsylvania
    4 cash?
    Sent from my HTC6500LVW using Tapatalk
