Free EOBD II Error Codes software
Discussion in 'General Diesel Discussion' started by Keithuk, Aug 30, 2010.
  1. Keithuk
    6,822
    Sorry Jon I've been holiday for 2 weeks.
    You only have to register comctl32.ocx when you use VB6 IDE otherwise it should work by just added it to your Windows\SysWOW64 folder.
    I had a similar problem when I added my app to my nephew's Vista 32bit laptop it said comctl32.ocx not registered. I ran the EOBD II Fault Codes.exe As Administrator and it worked. All instructions are in the ReadMe First.txt as I've said. That's just the stupid way Windows works.
  2. Bill_Oddie
    Bill_Oddie New Member
    Feb 4, 2014
    4
    Audi A4 B8
    Telford
    Works fine for me, Windows 8.1 64bit.
    Couldn't find my error code though but will do another post about that.
    Nice one.
  3. Keithuk
    6,822
    OK new update.
    The last app had 7872 error code this one has 10,037 error codes. Now its gone over 10,000 I've programme it to show the comma.
    I've corrected a slight bug in the last version. If you click on an item in the list then you use the cursor keys to scroll up or down it was always one code behind. I programmed the Key Down and Key Press but I didn't programme the Key Up so that now works as it should do.
    I found an OBD site that show extra info like Tech Notes: When is the code detected?: Description: so I've added this info to the codes.
    I've written the new help file with WinCHM Pro so there is no need to download anything from Microsoft for the old Windows help files.
    This new app shows online PDF files no problem but you can't right click on it and save it so I've added Download PDF on the menu bar so you can open your browser and save the PDF where ever you want too.
    The download link has moved back the post #1.
    Bill Oddie - The only error I used to have was a error number 380 on Form resize. I don't know why this shows as soon as the app starts it goes to full screen size so it doesn't resize. I changed the code and it very occasionally shows but the app doesn't close.
  4. hytron
    hytron Member
    Jan 31, 2014
    75
    2006 VW Jetta TDI 1.9L
    Michigan, USA
    Sounds interesting. I would like to try it out. Does it work on Windows 7 32-bit OS?
  5. Keithuk
    6,822
    It works on all Windows 32bit systems if you download the basic package, if you have a Windows 64bit then download and install the installation package, read the ReadMe First.txt. I use Windows 7 32bit so no problem.
  6. Oldaccord
    Oldaccord Active Member
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
    Hey Keith, not sure if I'm doing something wrong but when I go to the rapid share to get the program there is nothing there?
  7. Keithuk
    6,822
    Well I don't know which browser your using but both apps have just downloaded for me IE11 and FireFox, so the files are there.
    The small package has been downloaded 65 times and the full package 91.
  8. Oldaccord
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
    Just tried again with no avail! I'm copying and pasting the link in your install guide! You have the address in your instructions as
    EOBD II Fault Codes Installation Package
    Original EOBD II Fault Codes
    If you have used my app before and it works as it should then download this updated version and replace the exe.
    A newer version of the older app is still available as it now has 10,037 error codes.
    What's the chances of reporting the download link that works for me?
    Edit: Keithuk Download links removed of an open forum.
    CaptRF likes this.
  9. Oldaccord
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
    Ok after I wrote the above post I clicked on the links and they worked! :werdbut worked yayyyyyyyyy
  10. Oldaccord
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
    Hey sorry for posting them but after you removed them, I tried those links again and they aren't working again!
    I DONT GET IT.
    could i get them emailed to me or working linkssent to me? i tried conversation with you but forum wont let me send you one!
  11. Oldaccord
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
    so i am using IE 8 on win XP too btw!
  12. Keithuk
    6,822
    My desktop computer is WinXP with IE8 as that's the newest version that plays on WinXP and that doesn't see the files I installed Google Chrome for RapidShare downloads.
    Install FireFox or Google Chrome to download it.
    I've checked my settings and I've changed Accept conversations from... from People You Follow Only to Members Only so you should be able to make a conversation.
  13. Oldaccord
    Jan 11, 2014
    649
    1998 Beetle TDI
    BC, Canada
  14. imran333
    imran333 New Member
    Jan 12, 2014
    Vw golf mk5
    Uk
    rapidshare link not working can you send me a working link ive messaged you
  15. Keithuk
    6,822
    Both links work for me I've just tried both of them on IE11. They won't work on IE8 you need to install Google Chrome or FireFox to download them. I've just replied to your PM.
  16. losvre
    losvre New Member
    Aug 4, 2010
    Golf GT TDI/ 1998
    Subtle mods, mostly for aesthetics
    Hello all,
    Just to confirm that this app works on Win7 Enterprize 64bit. I got only one error about a file but I just ignored it.
    It works perfectly and I am grateful to Keith for spending so much time and effort to make this app.
    Cheers
    Nikos
  17. Keithuk
    6,822
    It was developed on Windows 7 32bit. I said you will get one error showing when it tries to install ieframe.dll this file is aways in use by IE just click the Ignore.
    Both download links work for me.
    CaptRF likes this.
  18. jimmyfrack
    jimmyfrack New Member
    Apr 23, 2014
    6
    2010 jetta tdi sedan and 2012 jetta sportwagen tdi
    NJ
    I'd love to take a look at he software especially since my car and its error code are driving me nuts
  19. Keithuk
    6,822
    Your welcome Jimmy but this version is 08-02-2014 so its 3 months old at the moment, I've added a few more codes since.
  20. Heinrich Krupp
    Heinrich Krupp Member
    Apr 29, 2014
    34
    2001 Jetta GLS TDI
    GTA Ontario
    Awesome Keith, thank you. Worked for me right away, click on .exe file. Xp sp3 and Chrome. Full setup complained of old files on system, do i want to update? yes, then must restart to run setup again. No way to restart anytime soon, too many things hooked to/running on this machine.
    Cheers
    H
