Fault code 01317
Discussion in 'Ross Tech VCDS forum' started by Dee Envy, Mar 21, 2013.
  1. Dee Envy
    Dee Envy New Member
    Mar 18, 2013
    2012 Jetta
    This is a fault I have been seeing in many scans on various forums but there are no solutions offered.
    A search has returned zero results. Is this something that has no significance and can just be cleared or is there a problem with the climate controls?
    This is a scan from my 2012 Jetta:
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 53
    Mileage: 29643 km
    Time Indication: 0
    Date: 2010.14.29
    Time: 03:36:42
    This is my first post here so Hello everyone. :)
  2. Keithuk
    7,236
    That fault has a Fault Priority: 6 which means The fault has a long term influence on drivability. Fault Code Screen
    VAG Error Code: 01317
    Fault Location:
    Control Module in Instrument Cluster (J285) - Check DTC Memory
    Possible Cause:
    Fault(s) stored in Control Module in Instrument Cluster (J285).
    Possible Solutions:
    Check Control Module in Instrument Cluster (J285) for Fault Codes.
    Special Notes:
    Control Module in Instrument Cluster (J285) stored a Code which influences other Control Modules Functionality.
  3. Ordka
    Ordka New Member
    Aug 30, 2011
    VW Jetta TDI 2011
    I am curious if it turned out to be anything? My A/C is acting funny...taking a long time to cool down and only gets to 40 -45 degrees. I checked the VCDS and I am getting the same code:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 6
    Mileage: 100490 km
    Time Indication: 0
    Date: 2038.14.18
    Time: 14:46:13
