Exhaust valve flap extended warranty, code P047f exhaust pressure control recall
Discussion in 'General Diesel Discussion' started by chittychittybangbang, Apr 1, 2013.
  1. chittychittybangbang
    23,891
    VW has finally admitted their exhaust valve was a horrible design and have issued a TSB (VWP-13-05) and extended warranty for the part to 10 years or 120,000 miles on 2009-2012 Jetta, Golf, JSW, Passat TDI. You should be getting a letter soon if you haven't already. If the car is throwing fault code P047f, it's probably sticking.
    Obviously, does not cover chipped or tuned cars, accident, vehicle misuse or neglect.
    As soon as I jacked up the new gen car years ago, I saw this was a bad design. The spring on the valve is exposed to the elements so it can rust in place. Quick and easy solution is spray the spring and whatnot with penetrating lube like PB Blaster. Then move it back and forth. Condensation can also collect in the exhaust and rust the pivot points.
    Refer to TSB 2031583 for the repair procedure. I can see it just unbolts and 1 plug, don't have that TSB. After replacing, if not working, use VCDS tool's basic settings exhaust flap calibration to reset.
    There is a newer design part which is hopefully better. The old part number is 1k0 253 691 d (1k0253691d), the new part number is 1k0 253 691 g (1k0253691g). I don't know the differences on the new part are since I haven't seen a car which has gotten the new part yet. The purpose of the valve is to generate exhaust backpressure to help the EGR (exhaust gas recirculation) system work.
    Here's a pic of it, more in the DPF FAQ: http://www.myturbodiesel.com/1000q/DPF-Adblue-FAQ-VW-Audi.htm
    [​IMG]
  2. StreetParked
    StreetParked New Member
    May 4, 2013
    6
    2011 Golf TDI
    Could this flap issue cause a no start / hard start condition on a 2011 Golf TDI? I've been struggling with a issue where a warm car will not easily start, won't show a glow plug light, shows an ECP error and a yellow engine icon.
    Thanks
  3. chittychittybangbang
    23,891
    If the exhaust is plugged, then yes I'd think it would contribute. I never took one apart to see how far it closes though. Not all the way I think so it shouldn't cause no start. 1st step, check error codes, your car is trying to tell you something.
  4. StreetParked
    May 4, 2013
    6
    2011 Golf TDI
    Thanks for the response. Two follow up questions:
    What's the best way to check the actual codes?
    How do I find dealers with good TDI techs?
    Many thanks
  5. StreetParked
    May 4, 2013
    6
    2011 Golf TDI
    Ok - just heard back from the dealer. They need to replace the ECM. The part is not in stock and will take awhile to get. The car is under CPO warranty, so I'm in the loaner until then. I didn't get much detail other than it took awhile to diagnose and recreate the issue.
    I'll keep you posted.
  6. StreetParked
    May 4, 2013
    6
    2011 Golf TDI
    I got my Golf back today. They replaced the ECM and the "damper" which I'm assuming is the exhaust valve flap. Covered under warranty. So far, so good.
  7. cltest4
    cltest4 New Member
    Oct 20, 2014
    2013 TDI SPORT WAGON
    Plattsbourgh ny
    Does this apply to the 2013 tdi sport wagon I 'm at 40miles so just out of warranty and have P048A code stuck closed? The deal say that it is not covered.
  8. D01770@msn.com
    D01770@msn.com New Member
    Dec 9, 2011
    Jetta/2006
    Hey cltest4, any updates on your P048A code and dealer warranty response? I had the same code on my 13 Jetta TDI with 43000 miles 3 days ago. The code cleared itself after leaving the dealership and has been fine since. The SA also told me it was not covered.
  9. cltest4
    cltest4 New Member
    Oct 20, 2014
    Plattsbourgh ny
    The message was cleared but the dealer said it was still bad. I had it replaced and complained directly to VW they paid for 75% of the cost of replacement parts and labor.
  10. Bradleyj
    Bradleyj New Member
    Feb 22, 2015
    2010 VW Jetta Sportwagen
    Lakeville, MA
    Has anyone had a look at the redesigned part? I just bought a 2010 JSW with 91k miles and I want to check to see if this part has already been replaced. All the photos I see on the internet when I search for part #1k0253691g (which is the new part) still show the exposed spring. I'm assuming that this would not be visible in ther new design, but maybe I'm wrong.
  11. JTRI
    JTRI New Member
    Oct 10, 2012
    11
    2013 Jetta Sportwagen
    I just had the flap replaced on my 2013 Jetta Sport Wagon. The new part was used. Since the extended warranty only covered 2009 to 2012 years I had to pay for it. I did complain to VW and they agreed to pay 75 percent of the cost of parts and labor. I was satisfied.
  12. Dan Ortego
    Dan Ortego New Member
    Feb 25, 2015
    4
    2013, Bug TDi w/DSG
    Yuma, AZ
    18" Astro Wheels
    I see no mention of the New Beetle TDi 2013 > so it seems strange they got it right on the Bugs but not much else.
  13. djmatte
    djmatte New Member
    Mar 13, 2015
    2013 beetle
    ann arbor
    They didn't get it right on the bugs. My 2013 just tanked at 60k miles. I just paid for the Fox but Wil be arguing this in the next few days. Does anyone have a link to the warranty info?
  14. Bajszi
    Bajszi New Member
    Aug 19, 2015
    11
    2011 VW Golf Sportwagen tdi
    Regina, SK
    Did everybody get the new part#?
  15. Greymetal
    Greymetal New Member
    Apr 12, 2017
    '13 jetta TDI
    Guelph
    Hey guys, having the same issue with my TDI 2013, vwc doesn't want to cover anything. I made a long argument over weeks and nothing, I'll keep trying but wondering if anyone could provide me with some form or email or anything that shows you were covered from vwc about this issue and maybe they will help me after they see that... I have nothing else up my sleeve. You can block out your personal info if that is a issue.
  16. laminated
    laminated New Member
    Apr 13, 2017
    13 passat 15 golf
    eastern Canada
    have a look on the tdi forums n the flap someone from Boston got a 13 covered
