Emissions Workshop MAF but sounds like exhaust leak
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by ulsdfo, May 5, 2017.
  1. ulsdfo
    ulsdfo New Member
    Aug 9, 2016
    24
    VW Jetta MK5 TDI DSG
    Somewhere beteen here an there
    MALONE 1.5 EGR DELETE
    Hello All,
    I started hearing what sounded like an exhaust leak at low rmps/taking off, after several hours the "emissions workshop" light came on. I hooked it up the the VCDS and get the following reading. This car has 196,000 miles, with its second timing belt being installed about 10k miles ago. The Cam has never been replaced. The sounds goes through the the whole rev band. Limits at 5k. no black soot at exhaust tailpipe. I did lift the car up and couldn't find an exhaust leek at the back of the manifold. sounds more like the top back of the engine. Can I keep driving the car? Is it the MAF? or is the cam or followers worn out? any suggestions are welcome.
    Friday,05,May,2017,09:27:11:05414
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 15.7.4.1
    Data version: 20160216
    www.Ross-Tech.com
    VIN: 3VWST71K65M634343 License Plate: MAY 5 2017
    Mileage: 316170km-196458mi Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72 7D
    VIN: 3VWST71K65M634343 Mileage: 316170km-196458miles
    00-Steering Angle Sensor -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    1C-Position Sensing -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Cannot be reached 1100
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 038-906-016-BEW.lbl
    Part No SW: 03G 906 016 AC HW: 028 101 223 9
    Component: R4 1,9L EDC G000DG 7329
    Revision: --H01--- Serial number: VWZ7Z0E1915839
    Coding: 0050078
    Shop #: WSC 00001 128 00032
    VCID: 64E95509A74E991EFA-8030
    1 Fault Found:
    000257 - Mass Air Flow Sensor (G70)
    P0101 - 000 - Implausible Signal
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 1449 /min
    Speed: 42.0 km/h
    Temperature: 27.9°C
    Absolute Pres.: 1122.0 mbar
    Mass Flow: 21.33 g/s
    (no units): 2.59
    Temperature: 81.9°C
    Readiness: 1 1 0 0 X
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 042 H HW: 02E 927 770 AD
    Component: GSG DSG 041 0905
    Revision: 04004010 Serial number: 00000502090393
    Coding: 0000020
    Shop #: WSC 44551 111 44551
    VCID: 181131F92B868DFEA6-804C
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0021122
    Shop #: WSC 00066 000 00000
    VCID: 3A55CB71754ABFEE70-806E
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 AG
    Component: ClimatronicPQ35 066 0505
    Shop #: WSC 00000 000 00000
    VCID: 6CF93D294F9ED15EB2-8038
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000000054461
    Coding: F4098E02400418000014000000140000002077035C
    VCID: 2F43EA25BE086A46D7-807A
    Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605
    Coding: 00479279
    Shop #: WSC 00000
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
    Component: 1S AIRBAG VW8R 024 6300
    Revision: 03024000 Serial number: 0037KD01RCHE
    Coding: 0012627
    VCID: 2E7DF721B902634EDC-807A
    Subsystem 1 - Part No: 1K0 959 339 B
    Component: BF-Gewichtsens. 006 0003
    Subsystem 2 - Serial number: 6332MSME093A055FI
    Subsystem 3 - Serial number: 6342MSME080E735EN
    Subsystem 4 - Serial number: 6351HSME06324F6EH
    Subsystem 5 - Serial number: 6361HSME06564E317
    Subsystem 6 - Serial number: 63727SME065B1B7FG
    Subsystem 7 - Serial number: 63827SME06375A6B9
    2 Faults Found:
    02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
    003 - Mechanical Failure - Intermittent
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
    Component: J0527 010 0045
    Coding: 0010041
    VCID: 72C523516DBA07AE78-8026
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 971 D
    Component: KOMBIINSTRUMENT 3HL 2120
    Coding: 0006207
    Shop #: WSC 01057 444 87930
    VCID: 2C79FD298F1E115EF2-8078
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 2700105120064B
    Coding: 3F3F0B420F1002
    VCID: 2977043D80EC047609-807C
    1 Fault Found:
    01304 - Radio
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 120
    Mileage: 261243 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 18:48:06
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 1K5 919 965 HW: 1K5 919 965
    Component: Kompass 002 0001
    Revision: 00002000 Serial number: 0371356TNT1203
    VCID: 78D111790BC66DFE46-802C
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 3HL 2120
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2339
    Coding: 0001271
    VCID: 364DDF4141525B8E94-8062
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.4 1502
    VCID: 3041E959A33675BECE-8064
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
    Component: KSG PQ35 G2 010 0101
    Revision: 00010000 Serial number: 00000000000000
    Coding: 13100F880106083F3D06050FA0080F0490A540
    Shop #: WSC 00066 123 12345
    VCID: 022573915D1A372E68-8056
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    3 Faults Found:
    00931 - Locking Module for Central Locking; Rear Right (F223)
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 4
    Fault Frequency: 32
    Reset counter: 76
    Mileage: 0 km
    Time Indication: 0
    00930 - Locking Module for Central Locking; Rear Left (F222)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 12
    Reset counter: 117
    Mileage: 0 km
    Time Indication: 0
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 50
    Mileage: 249019 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:42
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
    Component: 08K Audioverst. 0006
    Revision: 00004000 Serial number: 00000008154938
    VCID: 2B7BFE358A101666FB-807E
    1 Fault Found:
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit - Intermittent
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0001271
    VCID: 3753D2454658A2868F-8062
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    012 - Electrical Fault in Circuit - Intermittent
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 D
    Component: Tuer-SG 021 2416
    Coding: 0000144
    VCID: 3147EC5DA83C7CB6C1-8064
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 D
    Coding: 0000144
    VCID: 3245E351AD3A47AEB8-8066
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D7FF02DB4041856E5-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,803
    Scotland
    PP764's, turbo and mapping
    Maybe egr related? I think if the egr is playing up or there's a leak in maybe the pipe from the exhaust manifold it can throw the maf out.
    Not sure if a bad maf could also throw the egr out though and cause the noise.
    Might be worth disconnecting the maf and seeing if the noise changes.
    ulsdfo likes this.
  3. ulsdfo
    ulsdfo New Member
    Aug 9, 2016
    24
    Good point. I just replaced the valve cover gasket, and it has stopped the seeping oil to the back of the motor. This may have caused the gasket to fail, but I have not diagnosed it either. It's hard to observe as the egr is in the way. I will try to get a camera behind there tomorrow.
  4. ulsdfo
    ulsdfo New Member
    Aug 9, 2016
    24
    Cam is blown, engine is done. Finished with VW. Thanks everyone. Good luck to all of you.
