EA288 soot reset
Discussion in 'Mk7 VW Golf, Sportwagen and Audi A3 TDI forums' started by mikeme, Dec 3, 2016.
  1. mikeme
    mikeme Active Member
    Jan 29, 2013
    644
    2009 JSW TDI 205,000 miles sold back to VW after 6 hour emissions fix took over 4 moths
    Northern Virginia
    Has anyone reset the soot level on a 2015 TDI?
  2. Keithuk
    7,235
  3. mikeme
    Jan 29, 2013
    644
    Northern Virginia
    This is a follow on to
    http://forums.ross-tech.com/showthread.php?8409-2015-TDI-DPF-reset
    which started at
    http://forums.tdiclub.com/showthread.php?t=469809
    from the study guides, and use, we know that two soot models are maintained, and report quantities known as measured soot, and calculated soot.
    the measured one varies up and down as dpf pressure changes, and is also scaled with mass air flow and temps. during drives, this quantity will decrease during passive regeneration
    http://www.myturbodiesel.com/wiki/dpf-obd-charts/ includes a sample of data including the measured and calculated soot values over an hour plus drive
    the calculated is increasing only, except as active regeneration proceeds.
    I have watched both on my car, using both vcds, and a polar fis + installed on my car.
    when either soot level is past 45 grams of soot, the ECU will not run a regeneration. (per the SSG)
    where the dpf is really clogged up. (say from an unrepaired severe boost leak, or extended idling without regeneration), it does have to be pulled and cleaned or replaced.
    this would take care of the measured soot, but the calculated soot needs to be reset
    http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI
    explains the process. but the steps seem to be different for the latest updated engine controller.
    so my question is if anyone reading this has performed the soot reset on a US/Canada EA288 2015 TDI.
    and related to the data collection thread (which is a great example of users sharing data and gaining information) , soot is not ash, and it seems that the oil ash volume is similar to the calculated soot level, based on use, not derived from measurements.
  4. audi1z
    audi1z Member
    Oct 16, 2010
    417
    Audi 80 1Z Engine
    What ist the problem? Does the field regeneration not work?
    During a field regeneration, both soot levels are reset.
    Cheers
  5. mikeme
    Jan 29, 2013
    644
    Northern Virginia
    Seems that for the 2015 TDI engines, the ash reset adaptation also clears the calculated soot value.
  6. Keithuk
    7,235
