DSG transmission code GSY vs HLJ
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by tditom, May 9, 2017.
  1. tditom
    tditom New Member
    Sep 28, 2009
    22
    05 Passat TDI, 05 Beetle TDI, 99 Beetle TDI
    I have 05 beetle with DSG transmission per VIN code GYS W broken case needs replacement. Is code HLJ interchangeable with GYS. VW says they different transmissions.
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,413
    85 kubvan
    if vw says not same id trust them... things like gas vs diesel gear ratios and 2.5 vs 4 count... fyi.. its also tied into the immo/computer and what ever trans you put in will need reflashed by vw to work properly..
  3. Keithuk
    6,941
    Manufacturer: VW, Date(s) Used: 07/2003-, Model: New Beetle, Transmission Code: GYS, Transmission Type: 6A
    Manufacturer: VW, Date(s) Used: 07/2004-, Model: New Beetle, Transmission Code: HLJ, Transmission Type: 6A
    Manufacturer: VW, Date(s) Used: 04/2004-, Model: New Beetle, Transmission Code: GGZ, Transmission Type: 6A
    Manufacturer: VW, Date(s) Used: 07/2004-, Model: New Beetle, Transmission Code: GHE, Transmission Type: 6A
    Manufacturer: VW, Date(s) Used: 07/2003-, Model: New Beetle, Transmission Code: GHG, Transmission Type: 6A
    As taken from my new VAG Engine & Transmission Codes
