DSG to Manual swap, 5spd or 6spd?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by TheWifesTDI, Sep 2, 2017.
  1. TheWifesTDI
    TheWifesTDI New Member
    Aug 31, 2017
    2006 VW Jetta TDI
    Utah
    Hello all.
    I have joined this site because of the excellent technical data in regards to doing a 5 speed manual conversion on a DSG equipped 2006 TDI.
    I am close to pursuing this conversion but, I would like to hear anyones experience or opinions on their preferred transmission.
    What transmission would you use 6spd or 5spd any specific modifications I should look into for either while I am at it?
    The Jetta will be used as a daily driver and the primary goal is MPG and reliability.
    Thanks
  2. TheWifesTDI
    Aug 31, 2017
    2006 VW Jetta TDI
    Utah
    I have decided at this point, to go with the US market 2010 VW TDI 6 speed. The transmission I'll be seeking is PN 02Q-300-045-A.
    I was hoping someone would say the 5 speed is better because its from the same year, its also cheaper and there are a few 5th gear ratios I have seen online however, everything I have found suggest the 6 speed will provide better engine rpm to speed matching and better fuel mileage. I also noticed the 6 speed has a much larger case around the differential so I am assuming it will be stronger.
    Can I also assume the two output shafts increase strength?
    I am also hoping someone can check these attached gear ratios. I found them on various sites including this one:
  3. Keithuk
    7,128
    A 2006 Jetta can be 1.9 TDI-PD and 2.0 TDI-PD which is yours?
    Jetta 1.9 TDI-PD NARBasis 74
    Type Code: 1K2733
    Engine Code: BRM - 103PS
    Transmission Code: HLH HQH HQN HXU JPL - 6A
    Jetta 2.0 TDI-PD Trend 103fT
    Type Code: 1K2062
    Engine Code: BMM - 140PS
    Transmission Code: HDV JLU JRD KDN KNS KXX - 6S
  4. TheWifesTDI
    Aug 31, 2017
    2006 VW Jetta TDI
    Utah
    Hey Keith,
    The Jetta is a 1.9 BRM-PD.
