DSG Help! Only drained 3.8 liters
Discussion in 'Mk7 VW Golf, Sportwagen and Audi A3 TDI forums' started by Oldskoolmadskilz, Sep 11, 2016.
  1. Oldskoolmadskilz
    Oldskoolmadskilz New Member
    Jun 19, 2016
    2013 Sportwagen
    Austin
    Bought a used TDI and the service records only showed the 40K dsg service. Car has 99K on it. When I drained the oil, only 3.7 liters came out. IIRC, when I did my other sportwagen, I got about 4.6 liters. Is there any way possible that I didn't get a complete drain? So what to do? I know 3.7 is too little. Do I add 4.5? I don't have a vag com, so I can't do a bottom fill correctly.
    TIA
    Rob
  2. DubFamily
    DubFamily Active Member
    May 30, 2012
    911
    2014 BMW 328D xDrive
    Southern Maryland / DC
  3. mikeme
    mikeme Active Member
    Jan 29, 2013
    641
    2009 JSW TDI 205,000 miles
    Northern Virginia (dead in dealer parking lot since 15 august 2017)
    you could just put in the 4.5 (plus or minus a hundred ml)
    but if you want to use the snorkel to set the level, you really can do it without VCDS, if you have a $20-$30 IR laser thermometer. ( I would put closer to 5 l in prior to using the snorkel to set level. want to include enough extra to fill the snorkel and a bit to drain)
    [​IMG]
    the thin part by the drain tracks pretty close (within a degree C) to the internal fluid temperature I measured with VCDS.
    you could fill, run through the gears, when the indicated part of the case reads 35c, open her up and let drain till the fluid spurts, and seal it up.
    you would want to have the car level for the drain.
    the previous service could have been shy, or there could be some kind of leak. (perhaps a loose filter cap, or leaky filter O ring.)
