Drivers door functions failure
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by The_Hamster, Sep 21, 2017.
  1. The_Hamster
    The_Hamster New Member
    Jun 30, 2013
    11
    2011 Golf TDI Wagon
    Alberta Canada
    2011 Golf Sport Wagen TDI Comfortline
    The drivers door has lost the following functionality:
    Power locks - They do not lock or unlock with the remote. The power lock button does nothing. Though turning the key in the door does make all the other doors lock/unlock, and the remote functions all the other doors as well.
    Power mirror - Drivers door mirror no longer moves.
    Lighting - None of the switches light up on the door panel.
    The power window switches function normally but do not light up
    Going over this in my head I need to check - Heated mirror and integrated turn signal. Hatch release button.
    Anyone have any ideas as to what has failed, or is there a common wire that may of broke?
    Thanks;
  2. Dave N
    Dave N Member
    May 31, 2015
    53
    06 Golf TDI BEW 09A
    Spokane Wa
    Did everything fail at once or sequentially?
  3. Keithuk
    7,128
    Its common for door looms to flex and break the cables though I wouldn't have thought a 2011 has broken.
    You need to find someone with VAG-COM\VCDS to check the system out?
    We do have VAG-COM/VCDS User Locations but very few users add their details.
  4. The_Hamster
    Jun 30, 2013
    11
    2011 Golf TDI Wagon
    Alberta Canada
    I have VCDS. I'll give it a scan.
    They all failed at once.
  5. The_Hamster
    Jun 30, 2013
    11
    2011 Golf TDI Wagon
    Alberta Canada
    VCDS scan below. Door mirror turn signal works. Hatch release button works.
    Code:
    Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001429156
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 275D1D0B5E08B97EEB-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005210513
       Coding: 000490
    1 Fault Found:
    65793 - Supply voltage
              U1011 00 [009] - Voltage too Low
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 160
                        Mileage: 163092 km
                        Date: 2017.06.21
                        Time: 16:53:55
  6. Keithuk
    7,128
    That isn't a full AutoScan have you previously had door mirror turn signal showing up? I had that last year but I ended up buying a new bottom mirror cover £43 as they don't sell LED bulb strips. VAG are asses for doing that.
  7. The_Hamster
    Jun 30, 2013
    11
    2011 Golf TDI Wagon
    Alberta Canada
    There is no other pertinent information in the rest of the scan. The other door has a mirror turn signal warning on it, but this door does not.
    Code:
    01-Engine -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
       Component: R4 2,0L EDC G000SG  9971
       Revision: 12H10---    Serial number:
       Coding: 0050072
       Shop #: WSC 91590 999 80175
       VCID: 6DD12F237474532E51-8038
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 114B600C49250000880E06ED92190042350000
       Shop #: WSC 00066 123 12345
       VCID: 04076A8787FEB266AE-8050
    1 Fault Found:
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 41
                        Mileage: 166469 km
                        Time Indication: 0
                        Date: 2012.01.30
                        Time: 08:43:07
                 Freeze Frame:
                        Count: 0
                        Count: 32768
                        Count: 4608
                        Count: 397
                        Count: 50176
                        Count: 1
                        Count: 1535
                        Count: 0
    Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
       Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       Shop #: WSC 00066 000 00147
       ASAM Dataset: EV_Climatic A01005
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ED3282FB172A83668-803A
    Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
       Part No SW: 5K0 937 086 H    HW: 5K0 937 086 H
       Component: BCM PQ35 M    011 0035
       Revision: BJ011001
       Coding: 23380E38902F3EC4808000816000856C03000086535D8560648020000040
       VCID: 3979CB73B0BC3F8E8D-806C
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 14101  21  0512
       Coding: 009795
    Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R010JE.
       Coding: 00003046
       Shop #: WSC 00066 000 00000
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3979CB73B8BC3F8E8D-806C
       Crash sensor for side airbag: driver side:
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Component: S.Sens.Fahr.V  H01 ----
       Serial number: 3572MSME5D391456ZZZ$
       Crash sensor for side airbag: front passenger side:
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Component: S.Sens.Beif.V  H01 ----
       Serial number: 3582MSME49741256ZZZW
       Crash sensor for side airbag: rear: driver side:
       Component: S.Sens.Fahr.H  --- ----
       Serial number: 3511HSME5A711224ZZZD
       Crash sensor for side airbag: rear: passenger side:
       Component: S.Sens.Beif.H  --- ----
       Serial number: 3521HSME320A0C24ZZZF
       Crash sensor for front airbag: driver side:
       Component: F.Sens.Fahr  --- ----
       Serial number: 35527SME73195123ZZZ7
       Crash sensor for front airbag: front passenger side:
       Component: F.Sens.Beif  --- ----
       Serial number: 35627SME701A5123ZZZ6
    Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
       Part No SW: 5K0 953 507 AT    HW: 5K0 953 549 C
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JHG00052
       Coding: 1080140000
       Shop #: WSC 00066 000 00185
       ASAM Dataset: EV_SMLSNGKUDS A05001
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 020B6C9F95EABC569C-8056
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
       Part No SW: 5K0 920 861 A    HW: 5K0 920 861 A
       Component: KOMBI         H21 0204
       Revision: X0021007    Serial number:
       Coding: 181539
       Shop #: WSC 00066 123 00084
       ASAM Dataset: EV_KombiUDSMM9RM10 A04203
       ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
       VCID: 2B55E13B42E09D1E0F-807E
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 02101001210736
       Coding: E9807F0600020200002002
    1 Fault Found:
    01305 - Databus for Infotainment
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 219
                        Mileage: 119825 km
                        Time Indication: 0
                        Date: 2016.01.06
                        Time: 11:51:12
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 920 861 A
       Component: IMMO          H21 0204
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
       ROD: EV_ImmoUDSMM9RM10_VW21.rod
       VCID: 6ADB243F8D9A441634-803E
       Coding: 0004B5
       Slave Driver:
       Coding: 000490
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 160
                        Mileage: 163092 km
                        Date: 2017.06.21
                        Time: 16:53:55
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 3169F353A8CCF7CE35-8064
    Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001420694
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 285F1E375316B606E2-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005246323
       Coding: 000490
    1 Fault Found:
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 108
                        Reset counter: 73
                        Mileage: 166518 km
                        Date: 2017.09.11
                        Time: 12:27:02
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 02:09)--------------------------
