do I need a new vcds for my 2010 golf project
Discussion in 'Ross Tech VCDS forum' started by diesel?, Jan 18, 2016.
  1. diesel?
    diesel? New Member
    Sep 23, 2010
    29
    1996 passat tdi white, 96 passat tdi blue, 01 golf tdi, 2010 golf tdi
    so. cal.
    I bought a 2010 golf tdi and I am anticipating I need to change the injectors I think these are contaminated from a failed hpfp, and possibly they were replaced by the previous owner and he didn't tell me because there are 3 different part numbers on them. I was reading the how to article on the site and it says you need to program each one to work with vcds. I have a key com interface from ross tech I have used for everything else I have worked on, usually setting timing on ahu and alh cars, this is the first time working on a newer one. Will my old one work or do I need a newer one? thanks
  2. Keithuk
    7,170
  3. chittychittybangbang
    23,900
    Yep, you could buy a used one but it'll have to be the CAN-Bus.
  4. diesel?
    diesel? New Member
    Sep 23, 2010
    29
    so. cal.
    I am looking for a used one on ebay, will a MICRO CAN cable work to adapt injectors or do I need to get a HEX CAN
  5. iadubber
    iadubber New Member
    Nov 8, 2015
    2010 JSW TDI
    NE Iowa
    Yes micro can will do everything in vcds for your Golf.
  6. diesel?
    diesel? New Member
    Sep 23, 2010
    29
    so. cal.
  7. Keithuk
    7,170
    HEX-USB-CAN or the cheaper Micro-CAN.
