Diesel Dye
Discussion in 'Audi Q5, Q7, Touareg TDI, Porsche Cayenne forum' started by JRF, Nov 24, 2015.
  1. JRF
    JRF New Member
    Nov 12, 2015
    16
    2010 audi q7
    New Jersey
    Hello Forum,
    Does anyone out there has any experience in using diesel dye to locate an elusive potential fuel leak?
    Thanking you in advance for your feed back
    Best
    JFR
    23,900
    Also look for dirt stains, the dirt tends to collect around the leak and stick to it.
    Sparkn likes this.
  3. Sparkn
    Sparkn Member
    Mar 27, 2014
    211
    2014 Jetta TDI
    Illinois
    You need a UV light to go with it. You will get dye in the oil naturally. Only be concerned if the oil level rises unexpectedly. Be concerned of it migrates to the radiator fluid. I don't generally use dye in the fuel, because, like Chitty said, it almost always manifests as a dirt spot or leaves a varnish stain. The dye just helps you look at hidden areas.
  4. JRF
    JRF New Member
    Nov 12, 2015
    16
    2010 audi q7
    New Jersey
    Thank you all.
    The smell has diminished considerably. I almost forgot about it.
    I will keep looking for any greasy/dirty spots though
    I don't know if I told you guys the truck(do we want to think of Q7's as trucks?: I don't want to offend any purist,LOL) passed the emissions inspection after I drove the 500 miles, just as they told me it would.
  5. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    If your going to look at every fitting for color leak, then you can just as easily do a physical inspection.
    You might not be smelling it, because the rubber might be swelling up.
