Crankshaft gear removal 1.9 brm
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by donutman, Apr 19, 2017.
  1. donutman
    donutman Member
    Oct 10, 2010
    104
    2006 Jetta 5spd.
    north lawrence, ohio
    VR6 flywheel --Ross Tech VCDS
    I want to replace the crankshaft seal on my 2006 vw 1.9 brm. I have bought a high mileage timing belt kit and it comes with a new crank seal and bolt.
    I can not get the bolt to break loose even with an impact. The gear keeps turning even with the car in gear. I don't want to wedge a pry bar between the teeth and the cover. I am sure the aluminum cover would crack. Would I be able to use the crank lock pin kit , or would it just bend the pin. And do I need a puller to get the gear off once the bolt is out. Thanks
    23,902
    You need a crank yank tool WITH a breaker bar. This counterholds the sprocket. Even still, I have to have the car up high or else I don't have enough leverage. It's really tough. Make sure the car is secure and won't fall off the jackstands or lift. You can buy them here: http://www.metalnerd.com/cat05.htm , about 1/4 down the page. I don't use the OEM VW one because it only holds with 2 bolts, this aftermarket one uses 4 bolts which is much more secure.
    Don't use the crank lock tool because it'll cause damage if not just snap. I also wouldn't use an impact because I don't like the idea of shocking the forged crank. Although the metalnerd tool is strong enough for impact duty, I just prefer to not use an impact. Can't remember if you need a puller.
  3. donutman
    donutman Member
    Oct 10, 2010
    104
    2006 Jetta 5spd.
    ok, thanks for the info.
