CJAA in Tiguan with limited RPM
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by vwztips1, Oct 30, 2017.
  1. vwztips1
    vwztips1 New Member
    Oct 29, 2017
    4
    2004 Passat TDI manual, 2012 Tiguan TDI 6 spd
    Greenville, SC
    Just got through installing a complete CJAA with 6 speed manual from a 2013 Golf into my 2012 Tiguan. Drivetrain has 52k miles on them
    What I have done:
    New timing belt kit
    Filters
    CP3 fuel pump kit
    EGR delete kit from Darkside
    S3 intercooler kit from Darkside
    Engine wiring harness and ;ECU from Golf
    Accelerator pedal from Golf
    Tune from TDTuning with EGR and DPF delete (for off road purposes)
    Marin (jetta, 97 on TDIclub) performed cluster and immo swap on Golf instrument cluster
    I was not able to run engine before installing into the Tig as the donor car was trashed and had no key.
    I did fire up the motor before installing the timing belt and CP3 pump. Surprisingly it fired up after 3-4 turns.
    After the timing belt and CP3 pump I drove it down the road for the first time. I noticed it felt like I had no boost. I can here the turbo spooling up. It also feels like it has a governor on it, as once it gets to 2500 RPM the accelerator pedal does nothing.
    I had the EGR and DPF items unplugged so I thought it was in limp mode. After the tune it performs the same way. Also when sitting still and in neutral, it revs to 2500 and no further (this may be normal, can someone confirm?)
    No codes are present. Only exception is that after a 2-3 mile run I did get
    001037 EGR Temp Sensor 1 too high (not sure why since this is currently deleted out of the code)
    009571 Turbo boost control position sensor circuit - implausible signal - intermittent
    but cleared it and has not come back again.
    Here is what I have checked:
    Vacuum to N75 = 25
    N75 audibly clicks in test procedure
    Moved actuator with vacuum pump.
    Actuator does open when I unplug the N75 and/or sensor
    Actuator shows 6 ohms to ground on both pins
    Have power going to both N75 (12V) and Actuator (5V) plugs
    Unplugged the anti-shutter valve to make sure it was not closed
    Confirmed no rags or towels in the charge are lines
    Any pointers/advice would be much appreciated.
