Changing timing belt
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by erirob, Aug 14, 2017.
  1. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    Hello. I am charging my timing belt.
    I have installer the new belt but not starter the engine yet.
    I noticed that when I turned the engine by hand, the belt walked a little to the side. Closer to the engine. I think it just alligned to the tensioner and how the rest of the belt is planer but i am not sure. Could this be bad?
    I managed to fit both of the timing tools back into the spots after turning the engine. Am i 100% sure that the timing is correct then?
    I didnt manage to get the engine mount correctly back. One bolt is maybe 1-2 mm off to the side from there it was. Does it matter?
    Thanks!
  2. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    Sorry for typos. Autocorrect is a little annoying sometimes.
  3. Keithuk
    7,077
    What's the engine code of your 2006 Audi A3?
    TDI Timing Belts App
  4. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    The engine code is BLS
  5. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    The thing I am most worried about is the engine mount. It is the two 18mm bolts that i have not managed to get into position. It seems like the engine is a bit sideways compared to the mount.
  6. Keithuk
    7,077
    Have you read my app?
  7. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    No I dont have admin rights on the computer I am using.
  8. spazz
    spazz New Member
    Oct 15, 2011
    7
    Mk III Jetta
    With the engine supported, you shouldn't have any problems shifting the engine over to align the two holes up. Just put a little muscle into it :)
  9. spazz
    spazz New Member
    Oct 15, 2011
    7
    Mk III Jetta
  10. spazz
    spazz New Member
    Oct 15, 2011
    7
    Mk III Jetta
  11. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    Thanks. I will look into it!
    Another question. The plinger om the tensioner moves. Sometimes it is in the middle and sometimes it is to the left og the gap. Is this normal?
  12. erirob
    erirob New Member
    Aug 14, 2017
    8
    Audi A3 1.9tdi 2006
    Norway
    Not plinger. But indicator. Autocorrect
  13. mikeme
    mikeme Active Member
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    tensioner indicator moving with rotation is normal.
