Changing Oil Brands
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by eddi887, Sep 7, 2017.
  1. eddi887
    eddi887 Member
    Jun 18, 2017
    45
    2003 Jetta TDI
    Dale Texas
    Air intake
    Good Morning All,
    The 2003 Jetta TDI I bought a while back had Amsoil in it when I got it. It's due for an oil change and I wanted to know if changing back to an oil that is VW certified would cause any issues, or should I stick with Amsoil? The car has over 293,000 miles on it, so I don't want to do anything that might be detrimental to it.
    Thanks...Jeff
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,112
    Jetta 2003, Golf 2001
    As long as it's a high-quality synthetic Diesel-rated oil, you should be fine... the general quality of oil has gone up in the past several decades... I wouldn't worry about it... (I've been using Shell Rotella T6 (from WalMart) for a long time as well as the Castrol 505.00 rated stuff...
    Yuri
  3. eddi887
    eddi887 Member
    Jun 18, 2017
    45
    2003 Jetta TDI
    Dale Texas
    Air intake
    Yuri,
    Thanks for the feedback. I'll switch to a certified oil then.
    Jeff
  4. Pine Beetle
    Pine Beetle New Member
    May 17, 2015
    '06 VW TDi New Beetle
    Southern New Jersey
    Blue Moly
    Sent from my iPad using Tapatalk
  5. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,112
    Fine for the 2003-and-older TDI's... since you have a PD engine (2006), you'd better make sure to use an oil that conforms to VW spec 505.01 or higher - which, unless they changed the formulation since the last time I checked, the Blue Liqui-Moly doesn't have...
    Yuri
  6. Dave N
    Dave N Member
    May 31, 2015
    53
    06 Golf TDI BEW 09A
    Spokane Wa
    There are actually a couple Liqui-Molys that come in the blue jug that conform to 505.01 now both in 5W-40 which I use in summer and a 5W-30 which I use in winter.
