Car has blown 3 radios?? Help please
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Vw130, Mar 15, 2017.
  1. Vw130
    Vw130 New Member
    Oct 10, 2015
    26
    VW GOLF GT TDI 130 PD
    Ireland
    Hi, I have lost my partner in crime, companion or as I call it, my daily drug which keeps me somewhat sane. I am referring to my car radio. This is a factory standard cassette radio single DIN which is connected to a single DIN cd player in a VW Golf GT TDI 130 PD 2002.
    I cant remember for sure when I first noticed my radio was dead but it was within the last month and the only thing I can recall doing fairly recent beforehand was reconnecting my phone to my old Nokia handsfree kit which came already installed when I bought the car, and reminding myself to try and make use of it as it was fairly good. I hadn't used the handsfree kit more than 3 or 4 times altogether since I have this car as had planned on installing a different system, but that never happened yet.
    Anyway I am not sure if the radio just quit working after that or if it worked for a short while after that and then gave up. The handsfree kit never gave any bother any time I used it, it was just very loud sometimes. The handsfree kit works of the radio speakers so its connected to it. So around this time I have noticed the radio is not working. I have checked the following;
    1# Checked all the fuses at the drivers door side dash panel and all good.
    2# Removed the radio and checked the actual radio fuse in the rear of the
    radio and it is good
    3#Have tested for 12V at the radios power supply connector and have 12V on 2 wires with ignition off-not sure why theres 2 with 12V there
    4# Have tested all other wires/terminals in that same plug for power out of curiosity and found a lighter wire with 12V with ignition on and 3V with ignition off
    5# Tested for ground/earth at the same connector and it was good
    6# Checked for damaged wiring around the radio slot in the dash and all looked good.
    7# Checked wiring under bonnet and all seems good.
    8# Scanned for codes and just the usual codes been thrown up which I have had for ages not radio related to my knowledge. But one strange thing is I can no longer communicate with my radio using the relatively cheap VAG Scan tool. I used to be able to get a code from it related to the antenna. I presume I would be able to access it again if my radio was not dead.
    9# Have tried 2 more aftermarket cd players, which powered up but both only lasted for a few seconds. One showed a message PROTECT on the screen before it gave up, the other had a problem previously with a jammed cd drive which left it constantly running. ***P.S Neither of the 3 radios have blown any of the fuses***
    10# Tried bench testing the 3 radios straight of the battery by connecting what I believe to be the positive and negative terminals at the rear of radio to the battery terminals. Still nothing, no light or nothing on screen. Still no fuses are blown
    In the past I had seen this standard radio show the SAFE message on the screen after disconnecting the battery terminals while doing other jobs but only the first time I got a code from the dealers to get it working again, every other time it comes back to life by itself if given a few mins.
    So my heads really confused here, I was expecting something simple but I feel this is gonna drive me insane!! Can someone please please help me figure this out, any of your thoughts, advice or help is greatly appreciated and sorry for the long post
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,762
    Scotland
    PP764's, turbo and mapping
    See how many 12v lives you have with the ignition on, should be one for the battery live and one for the ignition live, two with ignition off sounds suspect. Might need to remove the key to test the ignition off as the radio stays on till the keys removed.
  3. Vw130
    Vw130 New Member
    Oct 10, 2015
    26
    Ireland
    Hi Seatman thanks for your reply. I have two permanent 12v lives with ignition on or off and even with key removed. There is also a 3rd smaller wire which has 12v with ignition switched on and around 3v with ignition switched off.
    I also thought it was strange having 2 lives with ignition off but have seen it mentioned on another forum that there are 2 permanent lives along with a switched live (smaller wire) and in the images it all looks the same as mine
    The 2 permanent lives are same size wires both are red and white and their right beside each other going into the ISO connector. The ground is the same size and is underneath them on the bottom row and is brown. Then around the middle of the ISO connector there is a smaller wire which must be the switched live.
    It's crazy how much trouble something simple like a radio can give you!! If you have any more thoughts keep them coming!!
  4. Oldaccord
    Oldaccord Active Member
    Jan 11, 2014
    654
    1998 Beetle TDI
    BC, Canada
    What year is this golf?
  5. Vw130
    Vw130 New Member
    Oct 10, 2015
    26
    Ireland
    Hi Oldaccord thanks for joining. It's a 2002 VW Golf Mk4 1.9 GT TDI 130PD
  6. Oldaccord
    Jan 11, 2014
    654
    1998 Beetle TDI
    BC, Canada
    Here see if this helps you at all
  7. gt4494
    gt4494 Active Member
    Jan 15, 2011
    418
    2005 NB
    Southeast Coast on I-95. Radar detector on and yes Herbie still gets 40mpg at 80 mph
    Don't have any clue whats going on with the radio but have you tried just playing elevator music. :)
    Sorry, I couldn't resist..
  8. Keithuk
    6,850
    I would say its:
    Manufacturer: VW, Date(s) Used: 05/2002-05/2006, Model: Golf/Variant/4Motion, Engine Code: ASZ, 96Kw, 131PS, 1.9 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    The GT is 150PS.
    Manufacturer: VW, Date(s) Used: 05/2002-05/2006, Model: Golf/Variant/4Motion/GT, Engine Code: ARL, 110Kw, 150PS, 1.9 Ltr, 4 Cyls , Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
