Cannot purge air in coolant system BHW B5.5 2005 Passat TDI
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Adam Chasen, Oct 4, 2017.
  1. Adam Chasen
    Adam Chasen New Member
    Oct 4, 2017
    5
    Passat TDI GLS 2005
    Raleigh, NC
    I had to change a stuck open thermostat in my 2005 BHW B5.5 Passat which opened my coolant system. All coolant I drained from the radiator looked like it was in great condition. Everything went well and now my engine temperature doesn't drop on the highway.
    Since then, I have had the occasional gurgle in my dashboard, but seems more likely when under load. AC system is not on, so it is not refrigerant. Heat appears to work just fine.
    I have performed multiple incarnations of the purge process with the weeping hole on the hose. Engine on, engine off, coolant cap open, coolant cap closed, lifted reservoir, etc. I thought it would purge itself over time, but it doesn't seem to.
    I did not backflush the heater core or oil cooler. Is it possible air bubbles are getting trapped in the heater core? I can't imagine that my heat would work well at all if the core were blocked to the point of holding back air.
    I would like to prevent the gurgling, but isn't worth a ton more time investment. Is there any issue with air in the system? I recall reading corrosion or wear issues. Any pointers on the next steps?
  2. Peca
    Peca Member
    Jun 12, 2013
    119
    Passat b6, 2007, 103 KW
    Pale, Sarajevo BIH
    Engine temperature should be constant it should not drop at any time when engine goes to operating temperature. VW engines should purge themself, you have to check if radiator hoses are hard after driving at the end of the day. If they are hard it means the additional air comes into cooling system. If they are normal you should replace heater core under the dashboard.
  3. Adam Chasen
    Oct 4, 2017
    5
    Passat TDI GLS 2005
    Raleigh, NC
    From where I have squeezed so far, they are not hard (hot, yes). Are there any hoses I should specifically check?
    I believe the system is under pressure quickly after starting. Wouldn't there be (big) leaks?
  4. Peca
    Peca Member
    Jun 12, 2013
    119
    Pale, Sarajevo BIH
    The hoses should not be to hard, especially after starting. When the engine is hot they should be a little harder then cold but not to hard. I think you have a head gasket problem.
  5. Adam Chasen
    Oct 4, 2017
    5
    Passat TDI GLS 2005
    Raleigh, NC
    A head gasket problem would be very sad news. Would (replacing) a stuck open thermostat exacerbate a head gasket problem? I do not recall having this issue before I replaced the thermostat (and introduced air into the coolant system). Any tests I can do? Any common weak points I can visually inspect? Would I see coolant leaks if the hoses or fittings had any issues?
    The coolant I pulled out of the car and in the reservoir and what has come out of the weep hole when bleeding after the thermostat switch appears to be clean. Would some introduced exhaust due to a small gasket problem make a visible/noticeable impact to color/smell?
    I am going to change the oil this weekend and will check for any contamination, but once again, would a small problem show?
  6. Peca
    Peca Member
    Jun 12, 2013
    119
    Pale, Sarajevo BIH
    If you had not a problem before thermostat job I doubt you have a head gasket problem. You just have an aditional air in system but I don't know how that happened, I changed a lot of thermostats and never had that problem. You have to go to your garage or dealer for precisely diagnose.
  7. Adam Chasen
    Oct 4, 2017
    5
    Passat TDI GLS 2005
    Raleigh, NC
    Thanks, will probably inspect a bit more thoroughly. Am I correct assuming that any crack or other "opening" which could introduce additional air into the system would likely leak coolant as well?
    Is anyone familiar with the the mechanism used to bleed air from the liquid loop in the sealed system? (not the weep hole, but how air is "purged" when in operation and sealed) I see the small hose at the top of the coolant outlet from the engine and believe that is the mechanism, but not sure. It also slopes down which I thought was a bit odd, but maybe that is to provide a little back pressure on the port to prevent a venturi effect of pulling air from the reservoir into the liquid.
    Any other troubleshooting tips? What would be the next step for a garage?
  8. Adam Chasen
    Oct 4, 2017
    5
    Passat TDI GLS 2005
    Raleigh, NC
    I possibly found a leak in the coolant system, but it is in a part of the cooling system which doesn't appear to have much information available. The suspected leak is where a small coolant hose comes from the metal coolant tube on the driver's side of the engine and goes "behind" the engine toward the cabin. I can't get a great look at it without removing parts of the EGR system. Anyone have details on what this tube goes to and its purpose?
    Still seeking details about the theory of operation of the coolant system.
    My current hypothesis is that when my thermostat was stuck open, a small leak in the coolant system did not introduce air into the system for some reason. After replacing the thermostat, a small leak is introducing air when the thermostat is "closed." From my testing, when I put a consistent load on the engine, it heats up, causing the thermostat to open. I hear air in the system I believe when the thermostat opens after being closed for some period.
