Buy back is in 4 weeks and the water pump starts leaking like crazy HELP
Discussion in '2012-2016 VW Passat TDI forum' started by B7tdaye, Sep 23, 2016.
  1. B7tdaye
    B7tdaye Member
    Jul 16, 2014
    46
    Vw passat 2013 Tdi SE
    Houston, TX
    And temp solution to keep the car goin other than putting water every 10 miles?
    S550 race red 5.0
    23,862
    You can try stop leak but these tend to gum up the system. The car is getting junked so might as well. Also, water will cause it to overheat, use 50/50 coolant. NOT green prestone type since it is not compatible and may foam, causing a problem that will not last until buyback.
  3. B7tdaye
    B7tdaye Member
    Jul 16, 2014
    46
    Houston, TX
    I've been using 50/50. But at $14 a Gallon, not sure $30 at min a day is the most economical solution "might as well get a rental"
    I read that stop leak won't work with Turbo cars.
    I'll try the water and maybe if I have to I'll do an 80/20 mix or something.
    I just spent $150 last week on a new battery smh.
    S550 race red 5.0
  4. chittychittybangbang
    23,862
    Your turbo is oil cooled only. I believe the radiator and intercooler coolant are also on different circuits.
    If your turbo was water cooled that would be a big no-no.
  5. B7tdaye
    B7tdaye Member
    Jul 16, 2014
    46
    Houston, TX
    VW covered the water pump under warranty. And they did the timing chain as well. So it's a Nguyen
    chittychittybangbang and Magnus like this.
  6. B7tdaye
    B7tdaye Member
    Jul 16, 2014
    46
    Houston, TX
    P.s the reason I gave up and went to the dealer finally is that I got a CEL and turned out the AdBlue heating element went out. Luckily I've never seen temp below 15 here in TX which when this would come in play.
    So that's 3 things the went wrong with the car in the span of 10 days!!! WTS?!
  7. clarkent5477
    clarkent5477 Member
    Jan 10, 2012
    55
    2001 VW GTI, 2012 VW TDI SE SunNav
    Precisely why I'm getting rid of mine. I had the same crap go wrong on mine and on a car with less than 60,000 miles. Unacceptable.
    Boosted-CHI likes this.
