BLB 2,0 tdi 16v
Discussion in 'Audi TDI forums' started by STIGARNE, Nov 2, 2016.
  1. STIGARNE
    STIGARNE New Member
    Nov 21, 2013
    15
    1998 vw passat 3b syncro 110 afn, Skoda octavia 1,9tdi pd 2004,skoda octavia 1,9 tdi 2004.2005 audi a4 b7 2,0 16v tdi
    Norway
    chip box
    Ok folks,whats happened is that my b7 audi a4 140 ps is stuck with hydrolock. Roomers says that its problably cracks in cylinder head
    which seems to be an issue on these BLB heads. First I thought it was head gasket...but. Can anyone confirm that cracks had been an issue
    on these machines? Grateful for answers !
  2. Peca
    Peca Member
    Jun 12, 2013
    96
    Passat b5, 2000, 85 KW
    Pale, Sarajevo BIH
    It is possible for cylinder head on 2,0 tdi 16v to crack. Anyway you will have to remove head and replace head gasket, and you also should perform a hydro test to see if there is any cracks on your head.
  3. STIGARNE
    STIGARNE New Member
    Nov 21, 2013
    15
    Norway
    chip box
    120000 miles, so easiest way is to change the engine I believe, new machine is less than 3000$ from Poland.
  4. Peca
    Peca Member
    Jun 12, 2013
    96
    Pale, Sarajevo BIH
    May be, but your repair should not be so expensive.
  5. STIGARNE
    STIGARNE New Member
    Nov 21, 2013
    15
    Norway
    chip box
    Yes, but an overhauled engine has upgraded oilpump too and new cylinder head. I have ordered a new overhauled engine, and can keep the old one.
