AUDI A4 B7 2.0TDI (170) SWIRL FLAPS?
Discussion in 'Audi TDI forums' started by john Andrews, Nov 15, 2016.
  1. john Andrews
    john Andrews New Member
    Sep 4, 2016
    9
    Audi A4 B7 2.0 TDi (uk) S-line Avant
    witney, UK
    hi all, i have a perminent fault code in the car, no lights, of my `swirl flaps` this i have been told may be stopping the car re-gen its own DPF, please, please can anyone shed some light on this for me, and give me any advice.
    thank you very much for your time.
    john.
  2. Keithuk
    7,026
    What error code are you getting?
    I'm guessing its:
    VAG Error Code: 008200
    EOBD II Error Code: P2008
    Fault Location:
    Intake Manifold Air Control Actuator/Solenoid, Bank 1 - Electrical Malfunction/Open Circuit
    Possible Cause:
    Wiring/Connector(s).
    Special Notes:
    Audi Factory Service Bulletin OBDII Code P2008
    Description:
    The Engine Control Module (ECM) detects that the position feedback of the manifold flow valve position sensor is not within range of adapted value learned during inplant initialization or after volatile memory reset. Intake manifold runner control open or short circuit.
    Intake manifold air control actuator/solenoid.
    Fault Location:
    Intake Manifold Flap: Bank 1 - Electrical Malfunction/Upper Limit Exceeded
    Possible Cause:
    Fuse(s).
    Possible Solutions:
  3. john Andrews
    Sep 4, 2016
    9
    witney, UK
    dont know the code, and it a 2.0L tdi
  4. Keithuk
    7,026
    As I quoted you've had a code from somewhere.
  5. john Andrews
    Sep 4, 2016
    9
    witney, UK
    (P3102) V157 intake manifold flap (throttle body) bolted to the EGR i believe?
    [​IMG]
    taken it out, given it a clean, see if that helps otherwise will replace.
    thanks for the help & comments.
    john
