ALH injection pump timing
Discussion in 'New TDI forum member introductions' started by mrmetric, May 19, 2017.
  1. mrmetric
    mrmetric New Member
    May 18, 2017
    2003 New Beetle TDI
    Paradise CA
    New to forum use, old to wrenching on VWs--as in air-cooled-- and frustrated at the lack of detailed repair info even on Mitchell, Alldata and Snap-on Solus Edge. You guys look to be the Mother Lode and I look forward to sharing lots of my painful lessons for insight into TDI world. Thanks!
    Sent from my SM-T377V using Tapatalk
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,126
    Jetta 2003, Golf 2001
    Welcome to MyTurboDiesel... did you have a specific question WRT injection pump timing? Do you have access to VCDS (new name for Vag-Com) or an equivalent diagnostic tool?
    Yuri
  3. mrmetric
    mrmetric New Member
    May 18, 2017
    2003 New Beetle TDI
    Paradise CA
    Thanks for asking, primarily concerned with change of sprocket bolts from angle torque back to conventional and which way to shade pump timing. I am a shop with SnapOn Solus Edge and am thinking 62-65 degrees? At 70 now and boy does it start great but am in CA heat and think that is a bit much. My whine is why send crank seal in kit and not stretch bolt for balancer along with all that other hardware--grr. It is all good though and you guys are a great resource, thanks again
  4. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    well vcds/vag-com sets it via a graph of fuel temp vs fuel quanity.. not degrees... so doubt the snap on tool will do much for you.. at least in good/useful info
    be careful on the length of those 3 bolts as too long will cause greif..
    most people lack the tools for the crankseal.. its a tty bolt too.. but same seal behind cam gear.. so kit came with 2 or 1? you need a way to lock the crank to do a twist of said bolt
  5. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,126
    The crankshaft and camshaft seals are not the same... 35x45x10 for the crank... 32x42x10 for the cam...
    Yuri
