ABS Code will not hold in module
Discussion in 'Audi TDI forums' started by Dakes55, Sep 4, 2016.
  1. Dakes55
    Dakes55 New Member
    Sep 4, 2016
    Audi A4 B6 1.9 TDI Avant AWX Engine
    UK
    I am having issues trying to Recode the ABS module on my car, AUDI A4 B6 1.9 TDI Avant 2002, I have done everything as stated in the ross tech video, log in, recode and it shows up ok, but if I turn off the ignition then turn it back on again the coding is lost and back to 00000 again, I have tried doing this about 10 times now and its not working, all brake warning lights on and message saying ABS not coded correctly, I am using a registered copy of VCDS Lite, any ideas whats going on here, it was all working ok before the ABS was unplugged
    23,902
    My best guess is that the ABS module is having an electronics fault. I've never heard of this before.
  3. Keithuk
    7,236
    What error codes are you getting?
    If you have a registered copy of VCDS Lite then join Ross-Tech forum and post a question with a full AutoScan?
  4. Arrkon
    Arrkon New Member
    Aug 4, 2014
    2005 Audi A6 Allroad, 2.5tdi BAU.
    Coventry, UK
    In progress, generic map.
    The loss of coding is normal on a Bosch 5.3 ABS/EDS/ASR/ESP -or- Bosch 5.7 (ESP also) vehicle when the slip ring / G85 sensor is disconnected. In this case you need to:
    1) Build the Login specific to the equipment installed in the car and enter it.
    2) Build the Coding and enter it
    3) Run the G85 calibration / Basic Settings
    All three of those steps must be done on the same ignition cycle and diagnostic session with VCDS as explained here:
    Audi A4 (8E) Brake Electronics (Bosch 5.7) - Ross-Tech Wiki
    If you know the old coding (based on a previous scan) work that chart backwards to determine the login without digging through the trunk for the PR# tag.
