A3 bkd bad diesel smoke
Discussion in 'Audi TDI forums' started by Boyce23, Nov 4, 2016.
  1. Boyce23
    Boyce23 New Member
    Nov 4, 2016
    Audi A3 bkd
    Wakefield
    Hi I've A3 140 20ltr tdi bkd engine I'm having really bad diesel smoke on start up if I leave it ticking over if I set straight off it's ok once cars warm it's stops I've Had it on machine coming up with cylinder 1 fault I've done compression test that's fine I've changed all 4 injectors the wiring harness for injectors change stretch bolts I've done everything I can think of or should I say the garage has which is costing me loads of money can anyone shed some light as I've only had the car 6 weeks and have been ripped off o and I've had to put a full clutch in please someone must no
    23,902
    Could try adjusting the timing a tiny bit. See the FAQ article on idle adjustment on PD engines. Bad camshaft? leaky injector?
  3. Andrewgud
    Andrewgud New Member
    Sep 1, 2016
    7
    2012 Audi A3 TDI
    Kent, WA
    Hi, very new here but in search of help.... I'm working on my 2012 Audi A3 TDI, and after replacing timing belt I cant get it run. I bought all the tools and aligned marks correctly.... It would start if I crank it for long time, but I am scared to burn starter as it gets very hot. Not sure if the pulley on the fuel pump is not cooperating with timing correct and what I mean by this is there maybe open/close valve on pump that is closing and opening in wrong time ( I did aligned pin correctly with "DE" mark on pulley and fork pin) It sounds like fuel is not getting delivered to injectors
  4. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Vw golf, mk5 2005 sdi, bkd engine
    Clacton
    Sounds like the fuel pump is not totally in timing, it only has to be a nats ass out.
    Do you have vcds?
    You can check the pump in a block graph.
  5. Andrewgud
    Sep 1, 2016
    7
    2012 Audi A3 TDI
    Kent, WA
    What is "vcds?" and is there instructions for aligning fuel pump?
  6. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Clacton
    Vcds - vagcom diagnostic software.
  7. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Clacton
    What engine code is it??
  8. Andrewgud
    Sep 1, 2016
    7
    2012 Audi A3 TDI
    Kent, WA
  9. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Clacton
    I was trying to look for the timing marks etc but I don't have it on my laptop here,
    I assume it's the same or similar set out to the CBAB engine, so I recommend you get vcds and measure the fuel blocks etc there are instructions online.
    Recheck the timing again as one tooth out on the pump with cause it not too start
  10. Andrewgud
    Sep 1, 2016
    7
    2012 Audi A3 TDI
    Kent, WA
    I have re-done timing belt 3 times and I'm still facing same problem. After long cranking It would start for few seconds...
  11. Mar4ix
    Mar4ix Member
    Sep 19, 2013
    118
    Now audi p8, 2.0 tdi bkd, in past vw passat 2001 , 1.9 TDI , AVF
    Ireland, Dublin
    Have you ever opened fuel lines while doing timing belt , replacing fuel filter or other reason like gain access to engine.? If yes, then more likely car wont start, as there is no fuel pressure in rail system. To gain that pressure, need to have vag com (vcds) cable, and run external pump (located in tank) for 5-10 sec, to gain a pressure in system. Not sure, might turn on ignition for 5 sec 100 times might work.
