'96 TDI Passat Oil Pan Bolts
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Taylor3609, Aug 23, 2017.
  1. Taylor3609
    Taylor3609 New Member
    May 6, 2017
    1996 VW Passat TDI
    Cambridge, NY
    Bought a 1996 Passat TDI for a DD with slight cosmetic damage to front end. Replaced all damaged parts. While tightening radiator bolt, dropped a socket down near the oil filter. Climbed under and noticed the pan is loose! Wondering if anyone has sourced out bolts for it before? I'd like to be ready when I get the car on the lift enough to see clearly. Thanks!
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,827
    Scotland
    PP764's, turbo and mapping
    Somewhere like idparts might stock them
  3. Taylor3609
    May 6, 2017
    1996 VW Passat TDI
    Cambridge, NY
    Thanks. I located a parts car with a blown engine close by, may even be able to buy the entire car relatively cheap.
