95' Passat Keyless Entry Now inop?
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Mark K Cunningham, Sep 8, 2016.
  1. Mark K Cunningham
    Mark K Cunningham New Member
    Sep 5, 2016
    4
    B4 VW Passat 95
    Cleveland
    268 cam set modded ECU chip, Modded intake, High flow Cat, Dual Borla mufflers
    The 95' Passats used a keyless entry remote. No RFID chip needed to start this car. The remote for the car only locked the car but never unlocked and suddenly stopped working. Changed batteries and as usual on a lot of the Jettas and Passats the remote still wont work. Manual locking is good including the confirmed alarm beep. I did a lot of research on this and the wifes Jetta with no results. I did the 10 second unlock position and got 3 beeps but no remote reaction. Could it be the remote itself or the little white module box behind the head light switch has gone bad. is there a way to test one or both the remote or box?!
  2. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Look for manual rematching of KEYFOB.
  3. chittychittybangbang
    23,902
    Also I removed your post in the wiki. It was redirected elsewhere anyways. If you have something for sale, please post in the classifieds.
  4. Mark K Cunningham
    Sep 5, 2016
    4
    B4 VW Passat 95
    Cleveland
    Oh ok sorry about that. Gone anyways.
  5. Mark K Cunningham
    Sep 5, 2016
    4
    B4 VW Passat 95
    Cleveland
    Can I ask what you mean by that?! Do you mean find a place that has the same keyfob by ID numbers
  6. xeno555
    Dec 12, 2011
    1,684
    Mile High
  7. Mark K Cunningham
    Sep 5, 2016
    4
    B4 VW Passat 95
    Cleveland
    As much as I appreciate the link you provided mine has central locking system. The key itself does not have a RFID chip in the remote. It is however a keyless entry remote and that is all it does as well as set the alarm in the process. It does not require a chip to start the car.
  8. xeno555
    Dec 12, 2011
    1,684
    Mile High
    Link has nothing to do with RFID... You can only lead a horse to water.
  9. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    95 not 05... he has a actual key ring thats got button to do things.... completly different set up..
