2011 Audi A3 TDI, flashing glow plug light, CEL on and code P2101
Discussion in 'Mk7 VW Golf, Sportwagen and Audi A3 TDI forums' started by Oblivian, Dec 10, 2015.
  1. Oblivian
    Oblivian New Member
    Dec 10, 2015
    4
    2011 Audi A3 TDI
    Oregon
    Hello,
    New to the forums, and need some help. My A3 is showing the glow plug light flashing on my dash and the check engine light is on. I pulled the code with an OBD II reader and I have P2101 coming up. The car still runs and drives fine. I can clear the code, all is well, but within a few days the lights and code are back. Most threads I have seen people have multiple codes or their car is in limp mode; not for me. Any ideas? Thanks.
    -Obliv
  2. Keithuk
    7,236
    VAG Error Code: 18533/008449
    EOBD II Error Code: P2101
    Fault Location:
    Throttle Actuator Control (TAC) Motor - Range/Performance Problem/Malfunction
    Possible Cause:
    Wiring/Connector(s).
    Throttle actuator control (TAC) motor.
    Possible Solutions:
  3. Oblivian
    Oblivian New Member
    Dec 10, 2015
    4
    2011 Audi A3 TDI
    Oregon
    Thank you. Is there a DIY or a FAQ related to this on what I'm looking for while trouble shooting? Just looking at the possible solutions I suppose I'm looking at the wiring harness connection to the throttle body (TAC I'm guessing), and maybe even removing and cleaning the TAC as well?
  4. Oblivian
    Oblivian New Member
    Dec 10, 2015
    4
    2011 Audi A3 TDI
    Oregon
  5. klazowitz
    klazowitz New Member
    Nov 23, 2012
    6
    Audi A3/2006
    Netherlands
  6. Eduardo perez
    Eduardo perez New Member
    Feb 4, 2016
    VW TDI 2009 ALH Engine
    México, Tijuana
    I'm Owner 2.0 ALH VW TDI 2009;
    My Main issue is Limp mode= No moré than 3000 RPM & LOOSE power; on the cluster: Engine+Glow plus+Engine flashing,,,I will apareciste Your similar experieces on this case,,,Regards
  7. Keithuk
    7,236
    Welcome to the forum Eduardo. welcometomyturbodies
    You don't say which model you have as the ALH is used in VW Bora, Caddy, Golf, New Beetle and Jetta.
    According to my spec the ALH is an old engine code which was first used in 10/97 Golf. The latest it was used was 03/10 in Skoda Octavia.
    VAG Engine & Transmission Codes
  8. Oblivian
    Oblivian New Member
    Dec 10, 2015
    4
    2011 Audi A3 TDI
    Oregon
    So I'm still having flashing coil light and check engine light. Update is now that the DPF service indication is on now too. The car still runs and drives fine, plenty of power. I have a friend that has the Ross-Tech software and ran the codes, any chance someone could translate them?
    Thursday,18,February,2016,17:10:58:35852
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    www.Ross-Tech.com
    VIN: ----- License Plate: -----
    Mileage: 194940km-121130mi Repair Order:
    Chassis Type: FM (8P0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
    77
    VIN: ----- Mileage: 194940km-121130miles
    09-Cent. Elect. -- Status: OK 0000
    0F-Digital Radio -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 CT HW: 03L 906 019 CT
    Component: R4 2,0L EDC G000AG 7273
    Revision: 12H10--- Serial number: AUX7Z0J8FND0BD
    Coding: 0350078
    Shop #: WSC 83968 937 404038
    VCID: 7F4EC4542E7170C607-802A
    2 Faults Found:
    009315 - Diesel Particle Filter
    P2463 - 000 - Excessive Soot Accumulation - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    RPM: 115 /min
    Speed: 0.0 km/h
    Pressure: 3 mbar
    Hex Value: 0xFF01
    Temperature: 24.0°C
    (no units): 0.0
    Mileage: 2550 km
    008449 - Throttle Valve Actuator Control System
    P2101 - 000 - Malfunction - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194948 km
    Time Indication: 0
    Date: 2016.02.18
    Time: 17:04:59
    Freeze Frame:
    RPM: 1127 /min
    Speed: 0.0 km/h
    Voltage: 10.87 V
    Lambda: 99.4 %
    Bin. Bits: 00000000
    Readiness: 0 0 0 0 1
    Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
    Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
    Component: SDAR SIRIUS H07 0160
    Revision: 00000000 Serial number: AUZ4Z7K0587812
    Coding: 0000100
    Shop #: WSC 06314 000 00000
    VCID: 3620E17041CB718E94-8062
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 194948 km
    Time Indication: 0
    Date: 2016.02.18
    Time: 17:10:09
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 S HW: 8P0 920 982 S
    Component: KOMBIINSTR. VDO H01 0090
    Revision: D0H01003 Serial number: 2248J003001871
    Coding: 0272288
    Shop #: WSC 23190 067 57207
    VCID: 49DA9A8C20350E76E9-801C
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 153923 km
    Time Indication: 0
    Date: 2015.01.23
    Time: 13:08:41
    Coding: 0272288
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 194948 km
    Time Indication: 0
    Date: 2016.02.18
    Time: 17:09:57
    Address 4C: Tire Pressure II
    Cannot be reached
    End-------------------------(Elapsed Time: 01:37)--------------------------
    I eliminated any of the addresses that did not have any faults to make a giant wall of text smaller :)
