2009 Tiguan S: 2006-2009 GTI MFSW Upgrade
Discussion in 'General Diesel Discussion' started by a1junkie, Jan 26, 2016.
  1. a1junkie
    a1junkie New Member
    Jan 8, 2016
    '09 Tiguan S
    Columbus, Ohio
    I'm working from this DIY.
    My '09 Tiguan S (basically a Golf 5 with a thyroid problem) has the auto tranny, lowline cluster display (red text, bottom-half only), and I've upgraded it to the RNS 315 head unit with internal bluetooth enabled. I picked up a 2006+ Mk5 GTI multi-function steering wheel (MFSW) with paddle shifters a while back, and I'm finally ready to put it in.
    My Steering Wheel Control Module (SWCM) comes up as 1K0 953 549 BF, which is mid-line, "Type 2," and uses software version SW 0101, according to this guide.
    My understanding is that to use the MFSW buttons or shifter paddles, I will need to upgrade to a highline SWCM. Is that correct, for both features? I could live w/o the buttons, since only half of them would be any use with my non multi-function display (MFD) instrument cluster.
    To select a high-line SWCM, do I just pick from the intersection of Type 2, SW 0101 highline units under Part Number 1K0-953-549? DOes that mean this unit should work?
    Some posts in the how-to indicate replacing the comfort & convenience control module as well- is that just for later vehicles where the SWCM is integrated into it?
    What if I manage to find some 2005.5 buttons, which replace MFD controls with more stereo controls - will it even matter, since according to this post, only Volume will work w/o an MFD?
    Thanks in advance.
    23,902
    I believe you need the highline SWCM. I'm not sure since I haven't done this myself with those exact parts. Please share what you learn.
  3. Magicmakin
    Magicmakin New Member
    Dec 18, 2017
    Tiguan 2.0TSI
    Poland
    Hi A1 junkie, I’m in a simular situation as you were in January. Did you have any joy with this mod? Best regards, Paul
