2009 TDI sportwagen radiator
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by 3cyl, Dec 22, 2016.
  1. 3cyl
    3cyl New Member
    Dec 21, 2016
    5
    2009 VW TDI jetta Sportswagen
    Danville Ky
    Buy back scheduled. Wife needs a new car now because HPFP went bad filling fuel system with metal shreds. I gave up on draining the radiator. Actually I figured out all by myself I was messing with the intercooler anyway.
  2. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    838
    06 TDI Jetta
    Marysvile, WA.
    What does the radiator or intercooler have to do with the HPFP? You may want to step away from car until you understand how things work under the hood...............
    What is the problem you are experiencing?
  3. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Then after spilling the headlight fluid, you just have to walk away.
  4. 3cyl
    3cyl New Member
    Dec 21, 2016
    5
    Danville Ky
    well, I was following a "how to" (http://www.myturbodiesel.com/wiki/cbea-cjaa-vw-jetta-golf-jsw-tdi-timing-belt-removal-part-1/) on replacing the HPFP that included removing an engine mount bolt and disconnecting the radiator line from the block. I felt pretty good about the how to and I've learned that dropping steps from a procedure isn't always the best idea. So I was looking to disconect the radiator hose and there are two nice fat black rubber hoses, one connected to the block at the front of the engine. Anyway they weren't radiator hoses and it's a fact I don't know what the intercooler does. Long story short I didn't remove the engine mount bolt or the radiator hose and at this point I have no idea why those procedures are recommended. I believe I can remove the sprocket on the HPFP and lock the timing with the room I have now. I could use some guidance on finding TDC on that car.
