2009 Jetta TDI Mil code P0401- EGR Insufficient flow
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by jherrera, May 30, 2015.
  1. mikeme
    mikeme Active Member
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    lots of guesses.
    no one will know until VW makes up its mind, convinces EPA it is a good fix, and they put the recall out.
    we may see some leaks or options in advance, but it will be difficult to judge if it is accurate.
  2. Denise Stanley
    Denise Stanley New Member
    Sep 9, 2015
    4
    VW Jetta TDI 2009
    Anaheim, CA
    That is a big issue. Why pay for a new DPF filter now ($3000-$4000) if it will have to be pulled later this year in the recall? Are you sure it is cracked? I (with a 2009 Jetta, 135,000 miles) just had mine pulled and cleaned (with the ERG filter indeed replaced). One dealer here said the DPF needed to be changed "to pass emissions" (false!). But if the DPF is really bad I'm guessing it hurts performance--not sure if you can wait a full year ???time until the recall. I would save your receipts in whatever case.
    Denise Stanley, Anaheim, CA
  3. n2fastcars
    n2fastcars New Member
    Apr 10, 2015
    6
    2009 jetta tdi
    Indiana
    I have soot in the tail pipe and in the egr filter. The P0401 comes and goes and I turn it off sometimes but it always comes back at some point. Then there are times it will comes on one day and then goes away on its own for a few days then be back after a few days later. Really not sure why that happens. Fuel mileage has been in the 42 to 45 mpg range but it is less then when I first got the car at 85,000 miles. It was closer to 50 mpg then. Like I said its at 125,000 now.
  4. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    the light comes and goes because the EGR filter flow changes as you drive. normal operation varies up and down.
    if (when) it became more plugged up the lamp would stay lit.
  5. Keithuk
    7,077
  6. mikeme
    Jan 29, 2013
    637
    2009 JSW TDI
    Northern Virginia
    What do they say about what?
  7. CRWalker
    CRWalker New Member
    Jul 20, 2016
    9
    2009 Volkswagen Jetta TDI
    York, PA
    ECS Fog Light Kit, Continental Timing Belts, Gates Water Pump
    I had the same code on my 2009 Jetta TDI and I heard a rattle under the car when idling. After putting it on a lift, I found it my Egr filter had seperated at the bottom of the canister. Just replaced the low pressure filter next to the EGR cooler. I've driven around town and highway for about 250 miles with no check engine light and no code present. There was minimal soot in the exhaust pipe directly after the DPF and minimal soot build up where the filter connects to the cooler. So I'm pretty sure that was it. I'll wait to see what the outcome is and get my valve cover replaced to stem the oil seepage on top of the engine. But as of now I have 4 requested regens since reset and 4 successful regens. Before replacement, I was getting a random successful regen every once in a blue moon. Hope this helps others!
  8. CRWalker
    CRWalker New Member
    Jul 20, 2016
    9
    York, PA
    Update: So I've got my car into the dealer for the emissions modification (still have the p0401 code in there). The deal with that is that if there is a CEL on, that has to be addressed first, alright good enough. Just got the call from the dealer, the fault pertains to the egr cooler! (Which is part of the emissions modification!) So, not 100% if it is also the DPF as well and just so happens to also be on the list of replacement parts and the Service Manager just didn't say so, but I thought I'd share what I just learned.
    Hope that helps all the MK6r's that don't get the hardware in the modification.
  9. Myridge
    Myridge New Member
    Aug 22, 2016
    VW, Jetta TDI, 2009
    Potosi, Missouri
    My 2009 TDI Jetta also had the same P0401 code when they did the mod and since the mod on the 15th that code is gone but so is about 10 MPG also. Now I have put on about 1000 miles since the mod and it certainly does drive different, feels like they neutered it. Lost the pep shifts weak and I went from 45-46 MPG to 35 I am not too happy. I may look into a DPF delete option and removing whatever it is they did. My car is going to burn through the so-called warranty they offer quick as I put about 60K miles a year and have 330,000 on my Jetta. Ran great up until they neutered it earlier this month.
  10. CRWalker
    CRWalker New Member
    Jul 20, 2016
    9
    York, PA
    Myridge is yours auto?
