2006 VW Jetta TDI $6800
Discussion in 'Diesel Cars and SUV' started by dieselboi, Feb 24, 2017.
  1. dieselboi
    dieselboi New Member
    Nov 24, 2014
    2003 VW Jetta TDI
    Southern MD
    VNT-17 205 Injectors Stage 2 Rocketchip
    So you've sold car TDI back to Volkswagen and now you're wondering what to replace you fuel efficient daily driver with. This is a 2006 Volkswagen Jetta TDI with the BRM diesel engine mated to a 5 speed manual gearbox. The car has 269000 miles but don't let that shy you away, every potential problem has been taking care of and steps have been taken to prevent any future ones. The car is in pristine condition for a 2006 on both the interior and exterior. Mechanically, the camshaft and timing belt were both installed at 205K, the car has been serviced with Shell T6 every 5K and Mann oil filter since. At 250K, the car received a Garrett GT1749V turbo upgrade with manual actuator to get rid of the electronic one. This with the Rocketchip 2+ tune really makes the car pull when you get on the pedal. The gearbox has Penzoil Snyrcomesh fluid which was changed 15K miles ago, at the same time the 5th gear swap was completed and the .658 gear was installed. This helps with fuel mileage, better top speed, and the longevity of the engine because the car is at lower RPM at higher speed, for example 60 MPH=1750 RPM as opposed to 2200 RPM. In December the car got 4 new glow plugs with a new glow plug harness. Disabled the DRL and changed the headlights, with 55W 8000K HID and Euro Switch. Interior is gray and in great condition with rips or tears. The car is Pkg 2 so it has heated seats, sunroof and satellite radio. The head unit has been upgraded with a NAV unit. Did the LED interior swap and the is so much brighter and it looks good with 30% tint. VW OEM TDI mats as well to keep dirt off the carpet. Suspension wise the car has Koni coilovers all around along with cross-drilled rotors and ceramic brake pads. Wheels are Elbrus 17 inch, wrapped in 225/45/17 with 8/32 of tread. The car needs nothing, I use Starbrie enzyme fuel treatment every fill up and consistently get 650 miles a tank, all with plenty of torque on tap at all times. $6800 OBO
    Located in Washington D.C. area
    [​IMG][/URL][/IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    mu2bdriver likes this.
