2006 New Beetle TDI idle
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by beetlegeorge, Feb 23, 2017.
  1. beetlegeorge
    beetlegeorge New Member
    Jan 27, 2011
    2006 New Beetle TDI. 1.9L, 5-Speed
    Orange Park, FL
    None
    2006 VW Beetle TDI 5 speed has good idle.
    On occasion, the idle will stumble lightly and it has a little wobble and then it goes away.
    Seems to have always done this. Is it normal or could it be an indication of an internal issue?
    thanks
    George
    23,804
    "Seems to have always done this" . You can check the timing but if it's not causing any problems or getting worse I wouldn't chase it. It's most likely related to the EGR system, flywheel, or timing. I'd just keep up with regular maintenance.
  3. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,661
    2012 TDI Tech Package 6mt
    Mile High
    Filters changed?
    Cold WX? Winter Fuel? Water?
  4. beetlegeorge
    Jan 27, 2011
    Orange Park, FL
    None
    Sounds like it's nothing serious but next time I get my timing belt changed, I'll have my diesel mechanic look at it.
    Not sure if the EGR is on my 2006 Pump Deuse diesel as compared to the pre 2006 ALH diesels.
    Thanks for the input gentlemen!
  5. Keithuk
    6,850
    Your car spec only says: New Beetle only, please add the year and the engine size would be nice? ;)
  6. beetlegeorge
    Jan 27, 2011
    Orange Park, FL
    None
    All done Keith.. sorry about that.
