2006 Jetta TDI won't start after timing belt replacement
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Train, Feb 4, 2017.
  1. Train
    Train New Member
    Feb 4, 2017
    Lake Charles, LA
    I started a tb job and locked down the crank sprocket and cam sprocket. When I was finished I made sure every thing was at tdc and checked again. Everything looked good when I got it all back together but when I went to start it, it would not start. I have seen videos of advancing the cam but I don't know which way to go or how much. I really don't know what to do.
    23,902
    I wouldn't suggest advancing the cam. If everything was good after turning it over twice, timing was fine. Try bleeding the fuel lines and making sure you have the right marks lined up.
  3. ncsteinb
    ncsteinb New Member
    Dec 11, 2013
    22
    2006 BRM Jetta Manual, 2002 ALH Jetta Manual, 1997 318ti w/turbo 6cyl (M50) swap
    Saginaw, MI
    Koni Yellow adjustable dampers, H&R Sport Springs, ECS Tuning Dogbone insert, ECS Single Mass Flywheel (both), EGR delete (both), Malone tune (both), BMW-> All of the mods!
    Double check, triple check your timing. I once found an engine that was a tooth off, no binding when barred over by hand, but refused to start.
    I second this.
  4. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
    Not sure where you got your cam locking pin. I bought one that was apparently oversized and did not set in the hole properly, it seemed like it did but my timing was way advanced ( I hand spun the engine first before starting so I knew the valves weren't crashing). when I looked at the photos on the fantastic write up, I noticed the knob set all the way in. So I ground down the pin and then it locked properly. So my question from my experience is did your cam locking pin insert all the way as in the photos?
