2006 Jetta TDI possible Immobilizer problem
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by lmbrown, Feb 28, 2012.
  1. lmbrown
    lmbrown New Member
    Feb 28, 2012
    2006 Jetta TDI 5-speed
    Hello All!
    I'm new to the forum. A few days ago, I dropped my credit card in the door and removed the driver's side door panel to retrieve it. After putting it back together, the door switches and windows (all the controls for the door) would not work. I pulled some fuses in the fuse box under the hood and that caused my engine fan to spool up to a high speed and then shuts off and then repeats. It will even do this without the key in. Well, after that happened with the fan, the door controls started working again. Now, my car won't sense if my driver door is open or not. The inside lights won't come on if the door is open and the light on the bottom of the door panel come on, but they will for the other doors that are open. And the trunk open light won't come on now when the trunk is open. The immobilizer light comes on when I first turn the key on, but it goes out. Whenever I start the car, it will start right up and then immediately turn off. And then about every other time that I try starting it, the car will turn over but not start (but usually starts right up the next time, just to immediately die again). And during all of this, the fan continuously speeds up and then shuts off. I've researched online and it seems that this may be something with the immobilizer. I've checked fuses, left the battery off, left the key in the ignition to reset it, tried all 3 of my keys; but nothing will work.
    Also, my car is a TDI 5 speed.
    Does anyone have any ideas?
    Thanks,
    Larry Brown
    :dunno
    23,900
    door issues could be this: http://www.myturbodiesel.com/1000q/a5/wiring-harness-vw-jetta-repair.htm
    The immobilizer light always comes on for about half second and goes out in every normal start. If it's tripped it'll say the immo is on if you have the full screen MFD and light will stay on. That does sound like immo turning it off but it always lets the car start just fine, not sometimes.
    Look somewhere else. Sounds like you have an electrical issue. Check fuses, battery cables, and grounds.
  3. lmbrown
    lmbrown New Member
    Feb 28, 2012
    Thanks for the quick reply! I will try looking into the electrical issues.
  4. lmbrown
    lmbrown New Member
    Feb 28, 2012
    I've ran a scan with a VAG-COM tool and got the following errors. I had to run the scan as a MK-IV instead of an MK-V. I verified that it is indeed a MK-V through the VIN number, but it isn't reading the CAN controller on my car. Does anyone know why this is?
    Here is the list of errors that I got:
    8 Faults Found:
    005712 - Powertrain Data Bus
    P1650 - 000 - Missing Message from Instrument Cluster
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 87
    Mileage: 205905 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:11:47
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.01 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    005687 - Powertrain Data Bus
    P1637 - 000 - Missing Message from Electric Load Controller
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 85
    Mileage: 205905 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:11:47
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.01 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 0.0
    005685 - Powertrain Data Bus
    P1635 - 000 - Missing Message from A/C Controller
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 85
    Mileage: 205905 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:11:47
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.01 V
    Bin. Bits: 11001100
    Bin. Bits: 00000000
    (no units): 16.0
    013112 - Control Circuit for Glow Plug Controller 1
    P3338 - 000 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 3
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 11001100
    Temperature: 13.5°C
    Bin. Bits: 00110000
    005441 - Fuel Pump Relay (J17)
    P1541 - 000 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.24 V
    Bin. Bits: 11001100
    (no units): 0.0
    (no units): 0.0
    001384 - Cruise Control Switch (E45)
    P0568 - 008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 945 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.32 V
    Bin. Bits: 11001111
    Bin. Bits: 11000000
    (no units): 1.0
    005705 - Powertrain Data Bus
    P1649 - 000 - Missing Message from ABS Controller - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 11001000
    Torque: 0.0 Nm
    Bin. Bits: 00000000
    Readiness: 1 3 0 0 0
    End ---------------------------------------------------------------------
    Any help is greatly appreciated!
  5. Keithuk
    7,170
    VAG Error Code: 18058
    EOBD II Error Code: P1650
    Fault Location:
    Controller Area Network (CAN) data bus, instrumentation - no signal
    Possible Cause:
    Instrumentation control module trouble code(s) stored.
    Wiring.
    Matching resistor in Engine control module (ECM).
    VAG Error Code: 18045
    EOBD II Error Code: P1637
    Fault Location:
    Controller Area Network (CAN) data bus, electronic CE - no signal
    Possible Cause:
    Trouble code(s) stored.
    Wiring.
    VAG Error Code: 18043
    EOBD II Error Code: P1635
    Fault Location:
    Controller Area Network (CAN) data bus, AC - no signal
    Possible Cause:
    AC control module trouble code(s) stored.
    Wiring.
    VAG Error Code: 17949
    EOBD II Error Code: P1541
    Fault Location:
    Fuel pump (FP) relay - open circuit
    Possible Cause:
    Wiring open circuit.
    Fuel pump (FP) relay.
    EOBD II Error Code: P0568
    Fault Location:
    Cruise control master switch, SET signal - malfunction
    Possible Cause:
    Wiring.
    Cruise control master switch.
    VAG Error Code: 17978
    EOBD II Error Code: P1570
    Fault Location:
    Engine control module (ECM) - immobilizer active
    Possible Cause:
    Incorrect/damaged key.
    Incorrectly coded.
    Engine control module (ECM)/Immobilizer replacement without coding.
    Wiring.
    Immobilizer defective.
    VAG Error Code: 18057
    EOBD II Error Code: P1649
    Fault Location:
    Controller Area Network (CAN) data bus, AntiLock Braking System (ABS) - no signal
    Possible Cause:
    AntiLock Braking System (ABS) control module trouble code(s) stored.
    Wiring.
  6. urgi
    urgi New Member
    Sep 29, 2014
    oooo A6
    essex
    please can you contact me
    email sonyvaiorepair@gmail.com
    we have exact same problem with Jetta 2006 TDI
    and need help please
  7. Snusspickle
    Snusspickle New Member
    Nov 6, 2017
    vw beetle tdi
    Philadelphia
    did you ever find the solution?
