2006 Jetta TDI (BRM) with severe power loss
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Nathaniel Mikkola, Jul 11, 2017.
  1. Nathaniel Mikkola
    Nathaniel Mikkola New Member
    Jul 10, 2017
    2006 Jetta TDI BRM
    North Carolina
    Hey guys! I'm new here and don't know a whole lot about car repair. I read the articles on limp mode and general power loss on TDI's and the common causes, but I'm a little over my head.
    I've already brought it to a mechanic, and he tried replacing a turbo valve (?) and the fuel filter, which seemed to help some but not completely. He said the fuel filter was really bad, so he recommended I put some additive into my fuel to clean it out which I have done.
    Whereas I'm used to feeling a surge of power when I get to about 1700 RPM, presumable when the turbo hits, now I'm only getting real power starting at about 2500 RPM and even then it's a bit weaker. I also don't hear any turbo whistle like I normally do. The engine light is not on, and IIRC the mechanic said it hadn't thrown any codes. I have a good bit of black smoke coming out the back when driving, especially up hills.
    Any help would be extremely appreciated.
  2. mattredmond
    mattredmond New Member
    Jul 19, 2011
    21
    Dallas, Texas
    You didn't say what kind of mileage you have on it AND I'm no expert. But I'll take a general stab at it and suggest that black smoke means you're running rich. Check for boost leaks. It could also be a failed turbo vane actuator (which is not a replaceable part unless something has changed). I believe a failing camshaft would also cause black smoke but you'd probably have other symptoms before that. I'd check that vane actuator first. If you can get a hand-held vacuum pump, put it on there and see if it holds position when you pull a vacuum.
    By the way, vane actuator (VNT, IIRC) and camshafts are known issues with these cars. I already went through the turbo issue and I'm replacing my camshaft this weekend. This car is a complete pain in the ass. I will never own another VW.
  3. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
    From my very limited experience, you really need something that can read the data stream from the engine management computer to figure this stuff out. If your mechanic does not have access the VCDS or something that can read the data stream, its a bit of a "blind squirrel" scenario. If you read the investigative wikis, most involve some sort of VCDS probing. So far in my 8 months of TDI ownership, my experience has been this is not a "just drive it" car, it requires tinkering, which I personally love to do.
    start at the front and work your way back :) Check your air filter, make sure it is not clogged. Check the air piping at the front and make sure it's not clogged. Make sure the turbo hose at the front passenger side (with the dog collars) is properly connected and seated, as well as the other end near the firewall. check the vane actuator. Verify your vacuum lines are not cracked.
    Matt, I rather enjoyed doing the camshaft a month or so back, I found it therapeutic :)
  4. 12G.Free
    12G.Free New Member
    Jul 31, 2017
    2006 Jetta Tdi
    Ontario Canada
    Is your car making a different sound than usual? (Almost like a Subaru boxer engine if you know what that sounds like) if so check under your hood with your car running and check the air tube to the right of your engine bay if it's shaking or you feel spurts of air pushing outward towards your hand you could very likely have a camshaft wearing out. Very common for our cars around 200km
  5. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    check the cam before you waste time/money else where...
