2006 Jetta TDi BRM hard start
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Jaguirre29, Jun 5, 2013.
  1. Jaguirre29
    Jaguirre29 New Member
    Oct 25, 2012
    6
    2006 Jetta Tdi BRW
    I have this 2006 Jetta TDi BRM that im having trouble starting. The car would start after cracking it for 15-20 secounds and after it starts the car would run fine with no problems unless I shut it off and leave for 5-10 min and ill have a hard time starting it again.. the car has a new cam shaft lifters and cylinder head and I also installed a new tandem pump I really dont know what could be causing this problem but my glow plugs are working and fuel pump is working as well
    23,902
    engine timing belt timing? Any error codes?
  3. Jaguirre29
    Oct 25, 2012
    6
    2006 Jetta Tdi BRW
    No theres no engine light on
  4. texas30cal
    texas30cal New Member
    Jun 7, 2013
    10
    06 jetta tdi
    I just completed the cam/lifters swap and have verified cam timing twice, I am having the same problem, immediately after installing the cam it would start fine, now have to crank 15-20 seconds and hold the pedal to the floor to crank it, once running runs fine. It does seem to be getting worse every time I start it, pulled the fuel filter and there was quite a bit of very fine glitter in it, on top of it and in the fuel in the canister.
  5. chittychittybangbang
    23,902
    Is the glitter magnetic?
    A few specks is normal in a 06, it's from the fuel, quite a bit sounds abnormal.
  6. texas30cal
    Jun 7, 2013
    10
    06 jetta tdi
    Will check to see if it is magnetic.
  7. mrciscoe
    mrciscoe New Member
    Jul 4, 2013
    11
    Central Jersey
    Jumping in an old thread, I just changed my cam and lifters, too. Same hard start. I will check the timing this weekend. It started great the first time after the job. Now it takes 3 or 4 tries to get it going. No codes or lights.
    Any resolution?
  8. chittychittybangbang
    23,902
    Did you
    Did you use the TB article on this site? If it's getting worse fast, either something in the TB is failing and/or getting loose, or the fuel lines are losing prime.
  9. mrciscoe
    mrciscoe New Member
    Jul 4, 2013
    11
    Central Jersey
    I did follow the site both times. I only changed the TB a year ago and now had to do the cam. Could be a fuel thing since I changed the filter, too. I'll be sure to check all of this Saturday.
  10. Patryk@DouglasVW
    Patryk@DouglasVW New Member
    Nov 7, 2013
    2004 Jetta PD 1.9L
    Summit, NJ
    Having the same issue after putting cam and lifters
  11. mrciscoe
    mrciscoe New Member
    Jul 4, 2013
    11
    Central Jersey
    RE-checked the timing again...took the belt off and started 'install' again. Car finally starts normally.
  12. jbern58
    jbern58 New Member
    Feb 10, 2011
    2005 Passat TDI
    Good to know on the timing fixing it mrciscoe! Can any of the other members who were having same issue post there fix? I just bought an 06 Jetta TDI That has same exact issue as all of you described. Super hard start cold. Once it’s running it seams to run pretty good, although I’ve noticed engine shaking for and aft a time or two, but not always. No CEL at all. In the last 70K miles this car has had both fuel pumps, cam and lifters, unit injectors, timing belt and associated components. 205K miles on it now. I bought it from the guy who was at his wits end with it. Really starting to wonder if timing is off a bit. I know it can be tricky to set on some TDI’s
  13. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
    I had this as well but my injectors were out of adjustment, once I adjusted them, the car started easily.
